Go Back   PowerStrokeArmy > Power Strokes > 6.4 Tech
Reply
Thread Tools Display Modes
  #1
Old 03-12-2020, 08:43 PM
F350eightyAM F350eightyAM is offline
Private
Member's Gallery
Default Low Fuel Rail Pressure at start up Long crank
My truck is slow to start. The fuel rail pressure is low at first while cranking then the pressure builds up in 3-4 second into the crank then starts. Any ideas of what it could be. ??? I've had electrical issues with the alternator over charging( 16V )replaced that today.
  #2
Old 03-13-2020, 08:34 AM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
could be a number of things, High pressure fuel leak, High pressure fuel pump issue ect. Is your engine oil overfull? That would indicate a leak.
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #3
Old 03-22-2020, 07:32 PM
Private
Member's Gallery
Default
No the there is not diesel in the oil. Changed out the hfcm same results
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
