Plastic square plug for if transmission
crashidy
Hey all, what is this rectangular soft rubber "plug " at the front of the transmission. Immediately behind the oil pan. Mine seems to be leaking oil.
Sent from my SM-G930W8 using Tapatalk
Mesa, AZ
That is just a plug that keeps **** outta the flexplate/converter area. If you pull it you can access the torque converter nuts. It is not the source of your leak, just soaking ul whatever oil is leaking...
crashidy
Thank you! It had a bed plate done at 75oookm but has always had a bid of a dribble. Nothing ever left on the ground. 310 000km on it now.
