Gauges
Phaney
Gaffney SC
Ok here is a question. I'm going to install gauges in my truck. I know I'm going with trans temp, exhaust temp, and I already have boost gauge. The question is should I get a hpop gauge or fuel pressure gauge to finish out my set. Thanks for any help.
Sent from my SM-G955U using Tapatalk
DEEZUZ
NO PUKESTERS
NWI
Fuel PSI hands down.
Saved my ass several times.
I would never run a gauge for hpo.. it can be read from data so I use that.
Phaney
Gaffney SC
Thanks fellows. That's the info I was looking for. Also what should fuel pressure always be reading and what kind of drop will indicate a problem.
DEEZUZ
NO PUKESTERS
NWI
depends.. stock fuel? stock regulator? stock truck should see 50+ and never below 45 wot full load.
I have fuel rail crossover/regulator and i use the middle spring so I have about 65 psi constantly and it never drops more than 5 psi
Phaney
Gaffney SC
Thanks. I'm in the process of doing the hutch mod, and gauges and blue spring kit on fuel bowl. Hoping later to do fuel bowl ******.
DEEZUZ
NO PUKESTERS
NWI
Factory fuel and filtration is best. Pre fiilter is an amazIng add on.
DEEZUZ
NO PUKESTERS
NWI
Unless you have other plans that require big fuel or oil.. I wouldn't.
BS Hauler
Northeast Iowa
I am running 8 ISSPRO gauges. 4 on the post and 4 where my rear view mirror was. I am running 1. Boost 2. EGT 3. HPOP 4. Fuel 5. Water temp 6. Oil temp 7. Oil pressure 8 Trans temp I like actual gauges.
Phaney
Gaffney SC
Yep. That's what I'm going with is actual gauges. I want to see what's actually going on.
BS Hauler
Northeast Iowa
I am 61 and I find it much easier at night to glance at gauges and read them than it is to try and read the constantly flashing numbers on these little screens.
