P245a code after egr delete
02bigstrokin
Put my no limit intake and full egr delete on yesterday and drove the truck today and I'm getting a p245a code according to the sct x4. I can't find any info on this code except for dodges?
MEDIC350
Michigan
P245A - Exhaust Gas Recirculation Cooler Bypass Control Circuit/Open
did you double check to make sure all the egr connectors are disconnected?
02bigstrokin
Thanks. I double checked everything. It's a full delete so I unhooked the butterfly valve, all three sensors on too of cooler and the temp sensor in short pipe. The cooler is out so I'm not sure what else would be plugged in?
