2015 Turbo Installation Questions
*BigBlack*
Kansas City MO
Hey everyone, I'm in the middle of the install and wondering about a few things before I go back and start installing everything. Does anyone know the torque specs for the passenger side exhaust manifold and the turbo torque down specs? Also, I was wondering if anyone has installed the a hot side intercooler pipe? I am wondering about the boots primarily because I cut one on accident and was gonna replace with a black boot where it meets the turbo but idk if it will hold. Any insight will be helpful. My truck is down until I get it all figured out. Thanks again
bdm1981
Salem, Missouri
I didn't really have any torque specs on my instructions when I installed the turbo pedestal. I just went on a cross pattern and tightened a little at a time to get an even pull so I wouldn't mess up the gasket. I have no leaks at all. As far as the specs on the exhaust manifold I wouldn't have a clue. I reuse the factory clamp on my hot side pipe to the turbo. Just a pain to get the clips to release and pull it off. If you have a good boot and a set of good clamps like the factory provides I don't see it being a problem. If I'm wrong someone please chime in...
*BigBlack*
Kansas City MO
Well on some of the 2015 retro fit kits, you have to replace the passenger exhaust manifold. I had a guy help me figure out the torque specs.
dsmracing1
Alberta, Canada
Go to the H&S website and utilize their 64mm turbo install instructions for specs such as torque for Exhaust Manifolds and the pedestal...
*BigBlack*
Kansas City MO
As a kit but slightly used with no instructions. I have been following your Review and Installation Jon but your SPE kit had different Up Pipes so you didn't have to replace the exhaust manifold.
jcain
correct. but i did have to replace them with the H&S kit. 25lbft for the manifolds and 35lbft for the pedestal
ford rules
What about any of the quick connect coolant fittings and such, anything prone to leaking that would be a good idea to replace?
