Traction control sucks!
DuvalJohn
Guys,
I want to WOT ON A MUDDY ROAD!
I hunt and at times don’t want to use 4wd. But with traction control & autotrac off, the truck still DE-tunes when the wheels break lose. What’s the fix?
Ez-lync & Forscan?
Thx for any help
mikeeg02
Drifting, PA
On the 11-16s you can disconnect the drivers front abs sensor down by the link arm. Retains Speedo and cruise. Disables abs/traction control/advanced track. I keep mine disconnected all the time. I cannot stand anything that takes away my ability to use the brake pedal. Or gas pedal for that matter.
8WR_ZJ
I have a switch I flip on and off that breaks the fuse. I got this idea from another member. It's called a "fun switch". Works great throws abs light and brake light on dash. After about 3 minutes of driving the wrench comes up. But as soon as i flip it back everything works great. No lights no wrench. My truck is an 15 model.
I will get the fuse number and stuff in a bit. And a pic.
04cr450
harford county, maryland
Why do this when u can disable the traction control by holding down the tcs button for a few seconds disabling the advanced trac control. 17's different?
mikeeg02
Drifting, PA
I think advanced trac re-enables after a certain speed. And I don't want to have to turn it on every key cycle.
That's my reasoning anyways.
8WR_ZJ
I thought it was over 45 mph and it enables. I know I can turn of by the TCS button and it shuts down when the tires spin at 55. With the fun switch it does nothing.
DuvalJohn
Buttons work, but if you’re on a muddy road and hit a mud hole and all you really need is WOT for a bit, Trac control will shut it all down. Luckily for me the mud hole was shallow and after slowing down to almost a stop 4wd was enabled to pull out.
I just want full control when “I” want it! ��. It is nice on the hard road when it’s kicks in and there traffic so if actually helps.
I’m going to try forscan.
Thx
Hawk388
I turn mine off and leave tire marks from 20-50mph.
Since I don't care about doing donuts or any of that ****, I'm pretty happy. If I preload the trans, I can burnout from 0-50mph. That's with hitting advance track off button, then holding it for about five seconds. But I don't want to burn my tires off. Did that plenty of times with my 2011 Mustang GT and got tired of replacing rear tires. So I guess I'm happy with what I can do. Going down sandy trails, the same settings let me get sideways going around corners even in 4Hi.
