Hot start problem
1995f2507.3
Have looked on the other threads to solve this and it's always coming down to a icp sensor. My sensor is from autozone so I can return it. I have been through 4 sensors in less than 2 months. Truck will run great and when I turn it off and try to restart it, it just cranks. I have 11.19 volts while cranking. What else is there to check. When the trucks cold will fire up everytime no problem. I dot have AE or a scanner to see icp or ipr. Should I consider changing out the ipr? I'm not sure how long this one has been in the truck. I have movement on my tach it looks like around 200 rpm while cranking. Any input will help.
1995f2507.3
Also when I unplug the icp sensor it has no effect on it starting or not.
Magnum PD
VA
Gonna need to see what pressure the injectors are getting. Changing the IPR might not be a bad thing. Coil could be bad
1995f2507.3
What could I get that's somewhat cheap to see what pressure the injectors are getting? Does the scan gauge 2 monitor that?
1995f2507.3
Where would I hook a mechanical gauge up to? What kind of gauge should I get?
1995f2507.3
If you could I would greatly appreciate it.
NotbrettboatIswear
It's an idea but that's also assuming that actual HPOP pressure is being reflected to the PCM. May or may not. A launch 123 pro works great with these trucks and they're like $200-250? Worthwild investment. The few 6.0s I've played with it also seemed to work great. Useless on a 6.7
1995f2507.3
Just checked the hpop and it's empty. So I wonder if my icp is good and ipr it's just not creating oil pressure due to the hpop having no oil. I checked about a week ago and it was full. Where could this oil have drained to?
1995f2507.3
Have you checked the oil level in the pan?
Oil level in the pan is at full, could this be the lpop? The truck does have 320,000 miles.
79jasper
skiatook, Oklahoma
From what I've seen, the lpop typically doesn't just fail.
Seen people talk about having cracked pickup tubes though.
1995f2507.3
Because it's now not even starting cold. It was driving great with lots of power on Saturday. So I'm not sure why it would just stop like it has.
