2009 powerstroke with noise on startup
Goosekiller
Grasonville Md
A week ago I installed a SCT live wire, no limit Intake and exhaust. After I was finished I started it up and took it for a spin with no issues. The truck sat for a few days and when I started it there was a whine / squeal when the motor turned over. Although I haven't had much time to really look at it the noise seems to be coming from the intake / alternator area. I removed the intake and reinstalled to make sure everything looked good but the noise was still there. Other then the noise the truck is running perfect. Any help on what's causing the issue would be appreciated, thanks.
https://www.youtube.com/watch?v=Xj5kvAznhWc&feature=share
johnnyroastbeef
South East PA
Could it be a leak somewhere in the intake tube? sounds like air getting sucked in. i'd first make sure all the clamps are tight and no obvious leaks on the new intake tube. i'm sure someone smarter than me will chime in soon who's had the same or similar isues. good luck
