Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-12-2020, 10:22 PM
glovemeister glovemeister is offline
Sergeant
Member's Gallery
Default 238/80's smoking on cold start
Curious if this is common.
Got a set of 238/80's that smoke on cold start, until eot reaches like 140-160. Then as if by magic perfect no smoke.
No bad hot, or cold start performance and no missing.
I had them pulled and flow tested, they found 1 bad nozzle and the rest were good.
Reinstalled and same thing.
I'm wondering if it is something internally that does not show on flow bench with fluids at regular EOT, or perhaps a tuning issue.
ETA: Forgot to mention e99 truck, and auto. So as far as I know I avoid the known zf6 timing issue from factory on these trucks.
  #2
Old 02-13-2020, 09:24 AM
mcnance865 mcnance865 is offline
Corporal
Member's Gallery
Default
If you are talking white/grey smoke, then it is pretty normal. My 238/80s will smoke when cold, but they start clearing up pretty quick. By EOT of 85-90 degrees it is clear. How much smoke are we talking? If it is just billowing, then you may have some other problem.
__________________
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
  #3
Old 02-13-2020, 11:15 AM
BS Hauler's Avatar
BS Hauler BS Hauler is offline
Sergeant
Member's Gallery
Default
I have never heard of the ZF6 timing thing. Would you explain.
I have a 02 with the 6spd.
__________________
2002 F-350 DRW 4x4 6 spd CCLB
2006 F-350 CCSB Auto 4wd
  #4
Old 02-13-2020, 04:01 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
How cold is it where you live?
Sent from my SM-G977U using Tapatalk
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #5
Old 02-13-2020, 04:07 PM
cleatus12r cleatus12r is online now
Sergeant
Member's Gallery
Default
NOT A THING.
Yes, there is an anomaly that exists but it DOES NOT have any effect when "fixed". It's a non-issue.
__________________
1973 F100 on 2002 4x4 frame AD/80%
2000 RC 2wd 250/200%
2000 SCLB 4x4 160/100%
1995 SCLB 4x4 SD axles/E99 Turbo/CAC AAs
2001 F350 4x4 DRW ADs
1994 Crown Vic 7.3L 4R100 AAs
1997 F-Superduty 5' stretched car hauler
  #6
Old 02-13-2020, 05:20 PM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Early '99 had XLE4 PCM, hard to tune compared to PMT PCM's
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #7
Old 02-13-2020, 06:12 PM
Barnbuilder Barnbuilder is offline
Sergeant
Member's Gallery
Default
Quote:
Mine is an AWA3. I put AC injectors in and it smokes like a train when it get cold out. Smells like unburnt diesel and don't walk through the cloud or you'll reek the rest of the day.
__________________
99 F350
15 F350
  #8
Old 02-13-2020, 06:38 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Quote:
Sounds like my California PCM’d OBS.
Doesn’t help that it was run for who knows how long before I got it without an air filter.....in dry, dusty West Texas.
  #9
Old 02-13-2020, 07:28 PM
Outlaw Bill Outlaw Bill is offline
Corporal
Member's Gallery
Default
Heck my Swamps 200/30's smoke like mad and idle rough at start up here in Michigan. They clear up really quick once moving and idle smooth.
  #10
Old 02-13-2020, 07:58 PM
Sergeant
Member's Gallery
Default
Thanks guys. So I guess it may be worthwhile to add a different PCM, as a portion of fixing this.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
