Oil flow valve?
Nic
Santa Fe, Texas
Hope I'm not beating a dead horse as I haven't been on here in a while. I recently had oil temp of 225ish while towing around 6k with my 2012 and the truck cut the power in half from the temp threshold from what I was told. I've heard that the problem is a faulty oil valve in the pan restricting flow, and I've seen where someone had a dislodged freeze plug that was restricting flow in the upper pan. Has anyone had a surefire cause and/or cure to this?
