Construction and Gains of Ported Intake Manifolds
windrunner408
Not the way you're thinking. The only thing you can do with a sealed manifold is to drill the posts out.
hawgdoctor
king george, va.
Abrasive playdo.:thumbup:
Essentially its an abrasive putty that is forced through the manifold under pressure to take out the casting flash, and make it as smooth as it can be without cutting it apart to do it manually.
Sent from my DROID RAZR using Tapatalk 2
