'95 F350 and T500 HPOP
Wackerjr
Hit him up, he usually has cores for the 95's he can build you one specific to your vehicle....
purpleheart350
Rokwall, Tx
I emailed them i just wanted to ask to see if anyone else has done it or has knowledge of it. If it wont work then I need to find something else.
Dieselboy.
Surrey B.C.
The T500 in my opinion is a better product for the price compared to the adrenaline.
FWIW I run a modded 17* from Joey and it does quite well with my 250/200s. The T500 is a bit bigger.
Talk to Joey, excellent guy to deal with and seeing as his twin turbo truck is a 95 I believe I think he can hook you up ;)
97f350stroker
Burgettstown pa
the t500 will work fine on your '95 with no drainback issue as long as you use an hpop from a '95 to build from. I had the same concern but Joey reassured me it would be find because I was sending him the '95 pump to build from.
