8 EDE Elite Diesel 250hp 105% 8 Hole Injectors & Nozzles 6.4L Powerstroke
Ford stroked
Blaine Wa
8 250hp 105% 8 Hole Injector Nozzle Tips 6.4L Power stroke
Bought Last Year Used For Less Then 500Miles, Changed Directions On My Project.
Bought From EDE All New Injectors & Nozzles. Worked Perfectly Before Removed With No Issues.
Paid New Well Over $5000 Plus $150 Core Each
Asking $2100
Our exclusive 8 hole injector nozzles will give you the increase you have been looking for. The OEM injector nozzle is a 6 hole design, by going to an 8 hole design fuel flow can be increased while keeping atomization high. Quicker throttle response, stronger mid-range and more total power can be had with these nozzles. These nozzles are precisely balanced, they are initially machined and then the machining is cleaned up with a final extrude honing.
