1995 F-350 Overhaul
Beau
Buffalo, MN
Started on this project a while back, starting to make some progress finally motor is getting machined right now.
Beau
Buffalo, MN
Few more pics of what is happening on the project. Currently setting up the engine with carrilo rods, mahle pistons coated -1.5 pts Compression ratio. Getting Balanced linehoned with girdle and ARPs,- heads ported fire ringed with ARPs, bowled shimed comp 910's. ,SRP 1.1, 300/200 injectors, Turbo setup S467 /S483 with dual 60mm turbosmart wastegates, and a small refrigirator / air to water intercooler. Phoniex Single Ceramic Clutch.
Hoping to make a few ponies, and still be decent to pull the bobcat around.
Any tips im open.
Beau
Buffalo, MN
some pics here
Beau
Buffalo, MN
So things have changes a bit and they always do. I was originally gong to run a twin but now it's going to be a thriple setup 66/82/106. Any hi I would like to run beehives from comp need some set pressure for the boost. Anyone running them. Wondering about insta procedure.
Thanks
Beau
POWER-STRUCK
Indiana
sounds like a cool build! the single ceramic might make it hard to pull and back a trailer, i've made that mistake a dual disc worked much better
Beau
Buffalo, MN
Very true, I figured it was going to be all or nothing pain in the but. I bought the clutch from a very small tranny shop here in St. Cloud. Nice old guy, so I bought whatever he had and this is what I ended up with. Thanks for the advisement can always swap it out.
Beau
Buffalo, MN
Some changes in build plan besides an additional turbo include. Injectors 400/200 from farmers via vision diesel. Regular air to air intercooler, got the whole turbo kit from Vision for to good of a deal and inter cooler from ponticross. Hpop setup will be my stock 15 and a gen 3 from another member on here. Waste gates changed to 46/39/39 all percision units. Anyhow hoping on getting my engine back by Friday.
bad12jr
I'd seriously look into a clutch. That clutch will die almost instantly with that many ponies. And the ceramic is either on or off. Not much slip if any. My ceramic /kevlar is not fun to back up and its no where near as grabby.
Beau
Buffalo, MN
Thanks, lol. Just got the motor back from my machinist, going to start assembling this week, once I get the motor assembled, Then the piping nightmare begins trying to get everything to fit.
