Sticky please.
jcain
Basic information we will need before we can help each other.
Year of truck
What turbocharger
What fuel upgrades (2015 pump, dual fuelers, injectors)
What Gears
Overall tire diameter
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason)
What is it you're trying to accomplish
What is it that your truck is doing that you are wanting to change
:popcorn:
Let's do this!
Year of truck
What turbocharger
What Gears
opcorn:
Let's do this!
lol.. needed to start this thread like 15 yrs ago
San Antonio Tx
Year of truck: 2015
Modifications:no limit intake, egr ******,5inch straight pipe exhaust, KEM tuning, Morgan's cold side piping, nitrous outlet duel stage of nitrous on progressive controller
What turbocharger: 2015 stock Vgt
What fuel upgrades (2015 pump, dual fuelers, injectors):stock 2015 hpfp lpfp and injectors
What Gears:3:31
Overall tire diameter: idk stock lariat wheels with toyos
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason):7780 , 7600 no interior, no fuel
What is it you're trying to accomplish: break a low 12 in a 4 door on stock motor and turbo
What is it that your truck is doing that you are wanting to change:for starters I'm KEM tuned, trans tuning needs a heck of a lot of work first. Second tuners need to make a all basic mod friendly tune( for example no limit intake) my truck throws a inefficient air flow code and doesn't allow me to remote start my truck. Third is the 40% throttle kick that happens when you're in town or in traffic. Gets very annoying feeling that clunk every time you stop and go, the position of the throttle is between 20-40% when this happens. Fourth my sync sometimes stops and tells me it's updating for no reason. Every time I upload a tune in the truck it happens and usually takes 30 minutes to finish up. Fifth thing I have to complain about is amount of low end torque. I don't know if it's just me but I'm able to lock my truck in 6th gear and at 1200 Rpms already be pushing Around 25psi of boost. I really don't feel comfortable spinning that low and the turbo coming on that quick.
Dzchey21
wyoming
Year of truck 2012
What turbocharger 64MM VGT from Midwest
What fuel upgrades (2015 pump, dual fuelers, injectors) Stroker 2015 pump from Midwest diesel
What Gears 3.55
Overall tire diameter 33s
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason) 8300
What is it you're trying to accomplish Tow a bunch of heavy things
Vengeance
Year of truck-2014
What turbocharger-H&S Kit
What fuel upgrades dual fuelers
What Gears 3:31
Overall tire diameter- 35
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason) 8300lbs
What is it you're trying to accomplish jackin around
What is it that your truck is doing that you are wanting to change not much actually
:popcorn:
Let's do this!
Powerstroked6.7
Washinton
I want to know how and where do you write so much about the details of your trucks, Im limited on space in my details section
CMCx2012
Long Island, NY
Year of truck-2011
What turbocharger-elite 3794 68mm precision wheel
What fuel upgrades- dual fuelers and a second LPFp
What Gears- 3:55
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason) Great question! My guess is 7700.
What is it you're trying to accomplish? Quality. Style. Power. Innovation. Reliability.
Tom@BigTimeKustomz
Bayville, NJ
Year of truck 2013
What turbocharger Stock
What fuel upgrades (2015 pump, dual fuelers, injectors) None
What Gears 3.55
Overall tire diameter 35
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason) 9500
What is it you're trying to accomplish MPG's, little extra power
What is it that your truck is doing that you are wanting to change Ride around in Tow/Haul all the time and trans shifts hard on Performance tune; SCT X4 with KEM tunes. Would like smoother shifts
:popcorn:
Let's do this!
jcain
Well we can't tune on the sct platform so we're of no help to you
Sent from my 831C using Tapatalk
Tom@BigTimeKustomz
Bayville, NJ
Year of truck 2013
What turbocharger S364.5SXE
What Gears 3:55
Overall tire diameter 35"
Approximate weight of vehicle ( cab and drivetrain configuration can be sufficient within reason) Approx 10k
What is it you're trying to accomplish Nice reliable daily driver
What is it that your truck is doing that you are wanting to change Can always make it better
:popcorn:
Let's do this!
Figured I'd update this since we just installed the turbo and Ez Lynk with Anarchy tunes. Currently running the 150 tune and it runs great considering I got used to the SCT/KEM tunes when I first put the truck on a diet.
