Go Back   PowerStrokeArmy > Headlines > Newly Enlisted
Reply
Thread Tools Display Modes
  #1
Old 06-16-2017, 06:50 PM
tippettc tippettc is offline
Private
Member's Gallery
Thumbs down 2004 6.0L with 5r110 issues..??
Hey all I have an 04 excursion with around 150k miles on it, well a while back started having charging system issues and then the alternator went out completely. Had the alternator rebuilt with all new parts and installed it.. charging system was back to normal but during all these charging issues transmission started doing that flaring and tow/haul flashing.... then after alternator was installed it continues and is showing solenoid D for a code..... replaced shift solenoid D and no change from what I'm told by my mechanic.... really need some help as my guy has been trying everything he can think of.... is the transmission toast maybe? I appreciate any and all feed back! Thank you.
  #2
Old 06-16-2017, 07:14 PM
Decker's Avatar
Decker Decker is offline
Sergeant
Member's Gallery
Default
When my solenoids went out, few shops told me my clutch pack could be toast also that the valve body could be toast. Not saying that's the issues but it a possibility.
__________________
06 F350 CCSB King Ranch
Studded, *******, upgraded banjos, blue spring,
6.7 fuel pump with sump, swamps 58v ficm
4in turbo back, coolant filter, guages, CAI,
SCT w/ IDP & TSD tuning & PHP ficm tuned
04 F250 CCLB XL - Sold
  #3
Old 06-16-2017, 07:45 PM
Private
Member's Gallery
Default
Yea we replaced the "bad" solenoid which actually ohm'ed out fine but replaced it anyway... and when we pulled pan the fluid was a little older as I bought it with 120k and hadn't done a tranny flush yet... but the magnet didn't have much of anything on it really.... so now we are at a stand still been that way for a little while....
  #4
Old 06-17-2017, 07:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Major
Member's Gallery
Default
I think you need to rule out an alternator problem causing this. You'll an oscilloscope to do that. Look for an AC ripple in the alternator output. That would indicate a bad diode. I've seen this exact thing happen from a bad diode in an alternator.
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
  #5
Old 06-19-2017, 01:47 PM
1ATony's Avatar
1ATony 1ATony is offline
Sponsor
Member's Gallery
Default
Thanks for joining
Tony
__________________
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
