Go Back   PowerStrokeArmy > Non - Specific > Project Forum
Reply
Thread Tools Display Modes
  #51
Old 01-05-2017, 02:38 PM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
this is great... I totally get that body work thing. I just don't have enough patience and my youth injured elbow would not tolerate the paint on paint off sanding.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #52
Old 01-05-2017, 02:57 PM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
Looks good.
I like what you did with the front of the frame to make the bumper fit. I am going to have to convert to a newer style axle and then do that same chop off the front of the frame. The width of a superduty frame isn't the same so ill have to deal with that as well.
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #53
Old 01-05-2017, 03:01 PM
300,000 and counting's Avatar
300,000 and counting 300,000 and counting is offline
Lieutenant
Member's Gallery
Default
Will the interior have the 1978 Dash? or the 1996
__________________
2009 6.4 PSD, Motor built by Rudy's, Trans Built by Warren, 59/76, 60%, No Limit goodies, PMF suspension
  #54
Old 01-05-2017, 06:18 PM
markfuga markfuga is offline
Sergeant
Member's Gallery
Default
The 78 dash will go back in. I'm going to try to "adapt" the 96 gauges to the 78 cluster to keep the retro look. I made an effort a while back but didn't get too far before other priorities took over. The goal is to keep the truck's classic look both inside and out.
  #55
Old 01-06-2017, 04:38 AM
gwunter's Avatar
gwunter gwunter is offline
Lieutenant
Member's Gallery
Default
So glad your keeping as much oem on the inside as possible!!
__________________
Just a crazy, wannabe machinist....making crazy stroker parts.
  #56
Old 01-08-2017, 11:20 AM
mandkole's Avatar
Major
Member's Gallery
Default
The dash adoption will undoubtedly be a challenge but so cool once it turns out
__________________
1994 F250 SCLB
(sold)
  #57
Old 01-08-2017, 04:14 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
Keep up the great work. Looking good. Great choice keeping the oem dash.
__________________
97-250 7.3 Eaton TVS Supercharged, S369sxe, R&D IDI performance T4 mount, my B350/200s, Honey Badger SR with My tunes, BMW M3 seats, Sky 5" RSK skyjacker drop pivot brackets, Sky shackles and hangers, Toyo M/T
1948 GMC Detroit 453T - 1945 Chevy C30 GM 451 - 1951 Mack A51T under restoration
  #58
Old 01-11-2017, 04:23 PM
Sergeant
Member's Gallery
Default
Thanks for the words of encouragement. Still moving along. Bed sanded to 2500 grit and ready for polishing.
  #59
Old 04-19-2017, 05:33 PM
Sergeant
Member's Gallery
Default
Making an effort this month to get back on this project. It's become very tight under the hood at this point but looking good. In the spirit of documenting specifically what I've done to merge the three trucks together here's some of the recent activity:
Steering column connected to the 05 steering box by using a 36 spline x 3/4 U-joint (Borgeson 113449) to a 3/4 double D rod (16 inches) to a 3/4 x 36 spline rag joint (Borgeson 053449) to the 05 steering box.
Extended the radiator fan shroud 2.75 inches to enclose the fan.
Connected the 96 power steering pump to the 05 hydroboost by using a 96 F-Superduty hose. I'm using the 05 steering box so the hose between the hydroboost and box is the standard 05 hose. I'm using a generic aftermarket power steering cooler mounted on the radiator support.
Used the complete 96 under hood wire harness and had to:
-Extend the wires for all the lighting on the drivers side of the truck
-Replace the side marker light sockets with the 78 marker light sockets
-The 96 has one extra side marker light, cut it out and tossed in trash
-Replaced the 96 headlight sockets with the 78 headlight sockets (all wire colors and stripes are the same for both years)
-The 96 turn signal sockets fit the 78 turn signal housings so no changes needed
-Used the 96 battery ground cables
-Made battery positive cables with military style battery terminals, copper lugs, 2/0 and 3/0 battery cable
  #60
Old 04-19-2017, 08:02 PM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
Nice!
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
