Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #11
Old 06-15-2017, 10:17 PM
eng53ine's Avatar
eng53ine eng53ine is offline
Lieutenant
Member's Gallery
Default
Can you read stored code as well with torque?
__________________
02 F-250, 7.3, auto, ccsb, 4x4, 4'' duals, 6637, IH bellowed up pipes, RiffRaff billet wheel, canned 6 pos. TS
  #12
Old 06-15-2017, 10:53 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Major
Member's Gallery
Default
Yes
Sent from my SAMSUNG-SM-G900A using Tapatalk
__________________
RANDY
2006 F250 CCSB 6.0 PSDFX4 LARIAT
SCTX2 CUSTOM TUNES, ISSPRO FUEL,AIR, FIRE,AND TRANNY
PRETTY MUCH STOCK
  #13
Old 06-16-2017, 05:42 AM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by Lubbockguy1979 View Post
Yes
Ok thanks
__________________
  #14
Old 06-16-2017, 08:15 AM
Major
Member's Gallery
Default
Torque reads codes better than most tuners, and also can read live info and i believe datalog. Forscan for a laptop can also do those those things as well as write to the programming on the truck to change limited things
__________________
RANDY
PRETTY MUCH STOCK
  #15
Old 06-16-2017, 02:14 PM
Powerstroke Man 6.4's Avatar
Powerstroke Man 6.4 Powerstroke Man 6.4 is offline
Colonel
Member's Gallery
Default
Personally I like the Forscan app over torque pro.
Forscan app has a cleaner layout and it's less "cluttered".
__________________
No Limit Fabrication
Midwest Diesel & Auto
  #16
Old 06-18-2017, 09:27 PM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default Car gauge or torque app?
Adaptor should be here by Tuesday, do either of those apps require anything else to be downloaded? I read on one of the apps I looked at you had to download something extra for fords.
__________________
  #17
Old 06-19-2017, 01:31 AM
Colonel
Member's Gallery
Default
Quote:
Forscan is all one app and ready to go out of the box with all available pids.
Torque Pro you need to enable the powerstroke extension and if some pids are not there that you want to see you to add them via equation.
__________________
  #18
Old 06-19-2017, 05:31 AM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
Ok thanks
__________________
  #19
Old 06-20-2017, 11:15 PM
Major
Member's Gallery
Default
Have a buddy with a 6.0 that is hard to start. Went to look at it today and within maybe 15 mins was able to determine the culprit of the no start. Having the ability to see what is going on is awesome
__________________
RANDY
PRETTY MUCH STOCK
  #20
Old 07-07-2017, 07:27 PM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
Ok got the obdll adapter and downloaded forscan app, what should I be watching? Where should the numbers be for i.e. ipr? I put a few things on but not sure where they should be.
Sent from my SM-T113 using Tapatalk
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
