Go Back   PowerStrokeArmy > Classifieds > Miscellaneous
Reply
Thread Tools Display Modes
  #1
Old 11-11-2019, 11:33 PM
powerlifter405's Avatar
powerlifter405 powerlifter405 is offline
Major
Member's Gallery
Default JTR Cap 218HT Home Pro audio sub
Selling my JTR Captivator 218HT. The 218 was originally developed which then morphed into the 4000ULF. http://jtrspeakers.com/captivator-218ht.html JTR develops systems for pro-audio and has transitioned to the home market. He is in Chicago if you want to see his offerings.
Dual 18's cab, 1400 watt ICE power amp. The large cab makes so a huge power supply isn't necessary but if you look at the specs, it works well w/in it's design parameters. The drivers are custom eminence 18's built to Jeffs specs using a 215oz magnet each.
I changed over to dual 2400's so the 218 literally sits in a corner waiting to be used.
The drivers and amp are in great shape. The cab has some white paint scrub in one corner from rubbing up against the wall at the previous house. Its not bad but it's there so i'm pointing it out.
If you're not "into" HT home theater or clear, clean HO audio then you're missing something. It will destroy anything you get at a box store and exceeds many other top tier brands for SPL plus it has extremely low distortion at those levels.
There are some threads on the AVS forums "subwoofer" sub-forum.
In NE its a big a$$ sub but the trade off is couch shaking lows from Star Wars, irobot, etc..
$1,800 OBO
__________________
05 original factory head gaskets, ARPs @ 302k torqued@ 250ftlbs, Redhead steering gear KC 63.5mm... factory stuff, rancho 9K's adj, 6.7 starter upgrade
  #2
Old 03-30-2020, 04:29 PM
Major
Member's Gallery
Default
Still available if any audiophiles are interested.
Thanks
__________________
  #3
Old 06-20-2020, 02:30 AM
Major
Member's Gallery
Default
sold
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
