Go Back   PowerStrokeArmy > Non - Specific > Engine Conversion
Reply
Thread Tools Display Modes
  #1
Old 07-03-2015, 05:09 PM
EasternOntarioPowerstroke's Avatar
EasternOntarioPowerstroke EasternOntarioPowerstroke is offline
Corporal
Member's Gallery
Default 7.3 in 6.4 Truck
Searched but couldn't find answer. I already own both trucks. 6.4 truck needs an engine, and 7.3 truck needs a cab due to rust in various places. I'd like to put 7.3 drivetrain into the 6.4 truck. I was wondering if the engine mounts would work interchangeably and if there is any firewall differences between an 99-07 cab and a 6.4 cab
__________________
2008 F-250 6.4 H&S MiniMaxx, Flo~Pro 5", EGR ******, Elite up pipes, DieselSite coolant filter
2008 F-350 6.4 Needs engine!
2000 F-350 7.3 TS 6 pos, FF 180/30, Flo~Pro 5", 6.0 trans/intercooler, Riffraff FRX/HPX, EBPV removed outlet/pedestal, DieselSite coolant filter, 05 front end, 07 dash swap
  #2
Old 07-03-2015, 08:05 PM
02BigD's Avatar
02BigD 02BigD is offline
Colonel
Member's Gallery
Default
Curious if you can get the electronics to play nice with each other.
__________________
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes from Matt.
04-250. ECSB - In the shop...future uncertain.
13 Flex. Limited AWD - EcoBoost - Tuned by Matt
13 Explorer. Sport 4wd - EcoBoost - Tuned by Matt
  #3
Old 07-03-2015, 09:21 PM
co04cobra's Avatar
co04cobra co04cobra is offline
Sponsor
Member's Gallery
Default
We did one. Electronics were a nightmare. I'll post some pics and info later.
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab
97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch.
08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc....
www.teddavisautos.com
Many parts available for super duty trucks PM me.
  #4
Old 07-04-2015, 07:33 AM
Corporal
Member's Gallery
Quote:
Quote:
Ideally I would swap the 7.3 dash into the 6.4 truck, and every electrical component. That is if the dash structure will fit an 08 firewall.
Please post some pics and any more info whenever you have time, thanks
__________________
  #5
Old 07-15-2015, 03:02 PM
co04cobra's Avatar
Sponsor
Member's Gallery
Default
Sorry I've been a little slow getting back to this. Here are a few under hood pics.
The 99-07 dash wouldn't work because they changed over to all electronic heater box, no vacuum, in 08.
Tying the 2 systems together was a real PITA. Also in 08 everything switched over to a ground system rather then a standard 12v control system. That proved to be even more of a PITA.
I'll dig up some more pics when I get a chance.
I would tackle this swap in a little different way if we were to do another one.
__________________
  #6
Old 11-20-2020, 01:09 PM
Moosef350's Avatar
Moosef350 Moosef350 is offline
Private
Member's Gallery
Default
Hey cobra, can you go over some more details? I’ve always wanted a 08-10 king ranch 7.3. I’m planning my swap now. Thankfully there are a good supply of wounded 6.4s. I going to stand alone the 7.3 with a zf6. And retain the 08 to run the everything else. Keep gauge cluster, using swap helper tach helper and put all 6.4 sensors in the 7.3 that are relevant. No cruise figured out yet though. Did super duty 7.3 engine stands bolt into the 08 chassis and how did the oil pan fit?
__________________
1997 F-250 hd, hand shaker,d60 swap,tymar,3 dp, 5 dual side pipe, billet pushrods, dp tuner, and some gauges
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
