Go Back   PowerStrokeArmy > The Bunker > Drag Racing
Reply
Thread Tools Display Modes
  #71
Old 09-04-2018, 10:34 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
This is going to be outstanding!! Nice build! Cant wait for it to hit the track!
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #72
Old 09-11-2018, 06:35 AM
jmoney jmoney is offline
Private
Member's Gallery
Default
Finally got the steering all done. Also got rear brake kit. Thanks to Devin at ********** machining solutions
  #73
Old 09-11-2018, 07:00 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Can i make one suggestion on the steering? Take an intermediate steering shaft from a classic duramax or something and include it in your steering wheel shaft at full extension, somewhere on the straight portion of the shaft. This way if you ever by chance hit the wall straight on, it will collapse the shaft as it is designed to do instead of turning the steering shaft into a spear. Maybe you already have something similar inside the tube up near the firewall-i cant tell.
  #74
Old 09-11-2018, 07:59 AM
Private
Member's Gallery
Default
Thanks for the idea, i am putting 2 stop collars on the shaft to help with shaft coming through the column I case of impact. Hope that's enough!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
