Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 09-28-2018, 01:58 PM
rman rman is offline
Sergeant
Member's Gallery
Default Harmonic Balancer Wobble?
How much is normal/too much. Changed my belt today and noticed a slight wobble at idle. I have not observed it at higher rpm
having a hard time uploading vid, here's a link
https://photos.app.goo.gl/UXDVMqRa8dJ9mKYh6
Sent from my SIG Sauer
  #2
Old 10-04-2018, 12:50 PM
bkb bkb is offline
Private
Member's Gallery
Default
very hard to see. It needs to ride true or it will cause vibration and not do its job of absorbing vibration. throw an indicator on it and get a real idea of how un true its riding. harbor freight can get you a cheap indicator and mag base.
  #3
Old 10-04-2018, 02:55 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
Completely normal.
__________________
Teamsters Local 444- Rolling Coal United
  #4
Old 10-04-2018, 02:57 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
These things simply do not fail. Unless the front main was leaking for like 75k miles and ate the isolator. I zip em off 250k motors and slap em right onto the new motors. No issues.
__________________
  #5
Old 10-04-2018, 05:56 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
Agreed. The only time I saw a failed one was on a six four that dropped a valve. The engine changed speeds so dramatically when it exploded that it damaged the balancer.
  #6
Old 10-06-2018, 06:13 PM
Sergeant
Member's Gallery
Default
Thanks guys. I had read that a little wobble was exactly what it was supposed to do, hence the name balancer. I assume it would spin like a top with some RPMs.
Tackling this laundry list of issues extremely slowly. A/C and my hyenda/duck howl are next. I'm hoping for carrier bearing vs anything front end.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
