Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-09-2018, 03:13 PM
Short Bus's Avatar
Short Bus Short Bus is offline
Major
Member's Gallery
Default transmission question
Ive got a customer with a 2011 c&c that bought a truck with a blown up engine. He bought a package deal used engine and trans with low miles out of what turns out to be a 2016. He wants the engine and trans both swapped out since the trans has alot less miles than whats in the truck. I noticed the parts tag has slightly different parts numbers. the 2011 is a bc3z-7000-m and the 2016 trans is a bc3z-7000-d. ford said they dont supersede to one another and doesnt know if they are interchangeable. Transmission guru's can i put the 2016 trans in the older truck w/o any problems????
__________________
03- f450 cc western hauler ******d tuned
  #2
Old 10-09-2018, 06:42 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Yes you can. The reason they are not interchangeable is because there are hard part differences between them. It will really screw up the next shop that has to work on it if they look up parts by vin but functionality is no problem.
  #3
Old 10-09-2018, 10:30 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Make sure you program the solenoid if numbers, should be a sticker on the side of the trans, otherwise, what sootie said.
Sent from my VS988 using Tapatalk
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #4
Old 10-10-2018, 08:30 AM
Short Bus's Avatar
Major
Member's Gallery
Default
thanks guys!
which sticker am i looking for? theres one on the drivers side behind the electrical plug and two on the passenger side. I can only read the one passenger side thats got a square bar code on it.
__________________
  #5
Old 10-10-2018, 11:07 AM
sootie's Avatar
General
Member's Gallery
Default
its on the passenger side iirc. it says Solenoid ID
If you dont have ids you can program it with FORSCan also,.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
