I just installed my trans with a suncoast rebuild kit and RCD converter and new ford pump. Everything seemed great right away but after a couple hundred miles it started to act up. Shifts great through all gears but randomly at idle, in gear it will stall. Like the converter is locking up. I checked and swapped the tcc solenoid with a known good one with no change. Also pulled the trans and swapped the pump with a known good pump as i was thinking it was a sticking torque converter control valve. Still nothing. The last thing I can think of is the converter itself is messed up. Am I on the right track? Is there anything else that could cause this?
Sent from my iPhone using Tapatalk Pro
