jtgf250
Dropped the freshly built motor in the truck the other day and went for first start up. Started blowing strawberry milk out the coolant tank. Thought maybe an o ring got rolled when putting together the oil cooler. Pulled apart and checked and all good. Then it hit me when pulling the lower radiator hose to empty the radiator that the mix wasn't dark but more like Pepto. So I pulled the trans cooler line and sure enough the same strawberry milk. Drained the trans pan right away.
Now, whats the best way to flush out the trans? Remove the return line and fill it back up and flush like usual or someone have a better idea.
Thanks In Advance
Thanks In Advance
