94.5 7.3L IDI exaust parts
Redman920-06 350
Wisconsin
Hey guys Im sorry if this is a Duplicate again, I have a 97.5 which is the time they were slapping turbos on the IDI to keep up with Cummins. I need the exhaust Y pipe collector piece, its in-between the manifolds and the turbo. I think I added a photo, its from the passenger wheel well.
Ad8 PRODIGY
Orange County, NY
IIRC The turbo was a factory option in 93, 94 it was a standard option, and 94.5 the PSD hit the market, just to clear up any confusion..
Redman920-06 350
Wisconsin
Good to know, I was told the 94.5 is when they started putting turbos on from the factory on the IDI motors because of a shortage of the new 7.3L Motor.
bad12jr
94 had 3 vins m k f. NA, turbo idi and psd. Good luck finding factory turbo idi parts. Just not a long enough a run. You may be able to call ATS as i believe they had a hand in it.
Fordguy100
Silverton, Or
Junkyards, nobody makes that part (if you are referring to the cast iron piece bolted to passenger side exhaust manifold).
Whats wrong with it?
old man dave
Petaluma, CA
Turbo IDIs were made throughout the 93-94 model year along with the N/A IDI. The 94.5 PSDs were stick only at the last half of the year. You're right about ATS, the factory turbo setup was a slightly modified ATS setup according to the reviews at the time.
Redman920-06 350
Wisconsin
so the general conciseness is I'm Boned. I hear ATS is gone, but HYPERMAX Engineering Might be able to help. Has anyone had luck with them?
Thanks for backing me up with the turbo IDI VS the PSD in that year, Many people dont know about the 94.5 being so goofy and why its Important to Specify the 94.5
bad12jr
94.5 was a stroke not idi. 94 is idi turbo or NA. Nothing about the 2 will interchange with out major mods.
Redman920-06 350
Wisconsin
According to ford Its a 94.5 IDI. No joke. And That's what sucks, Its IMPOSSIBLE to find these parts. I guess its just going to have be taken out and repaired...or fabbed. :cursing::fustrate:
Fordguy100
Silverton, Or
How big of a hole? Is it cracked, split apart?
I would take it off, and take it to someone who knows how to weld cast iron. Thats really your only option besides keeping an eye out for a used kit.
Redman920-06 350
Wisconsin
IF you guys know anyone at a junk yard have em keep an eye out, theres a photo under my first post of what it looks like (from the passenger wheel well.)
Dieselboy
Mine leaks at that joint too ill see if I can locate one or I may change my up pipes to run a different turbo. I had luck getting parts from ats before but it seems they're gone? It was 4 years ago that I put the same motor mid 94 idi turbo into my bronco. I have my engine on the ground so ill snap a few pics for you tomorrow.
Redman920-06 350
Wisconsin
sounds good! Lmk, BTW love the fact you put a IDI in your Bronco haha.
Dieselboy
Try calling ats. Last time I needed something the guy just went into the shop and found me one lol. Ill be taking mine apart in a few weeks and I don't know if I'm going to use it or not but here's pics of what the Y and up pipe looks like.
