#121
#122
Sweet. Can't wait to hear the reviews and/or see the results
__________________
2008 F350 King Ranch Engine build coming soon, 800hp goal 1988 Ford F-250 Larait 7.3L IDI Austen ❤️s Michaela
#123
Is the billit kit still same price? Also how much is shipping to Florida? I think I've been convinced to do a single kit with S366 even tho I love my twins
__________________
2008 F250 6.4 leveled 20x10 35x12.50 ******* tuned Egr blocked, 4" Straight Sinister coolant filter |
#124
Yes, just give the shop a call @ 217-691-1909 we will get you taken care of!
#125
I watched video and wondering how the spool is on a standard trans at a drag strip?
#126
My question is. I want to swap to a single turbo set up, but I'm needing advice on which set up would match my drivetrain and accessories upgrades? I don't tow I would daily drive 150-200 miles per day
I'm leaning towards a S366 which adds little HP & Less torque. I'm wanting to add EZ Lynk Tunes with the setup. Please Help Swapped Rear Differential 3:73 to 4:10 Upgraded Two Piece Driveshaft w/ Thicker Frame for Saddle ppBearing, ATS 5R110W Stage 2 Upgrade, 8" Pro Comp Stg.2 Lift, 38/13.50/20 M/T w/ 20x12 -44 offset Wheels, Fully ******d w/ Computer 150hp Tune. 4" Straight Exhaust, Factory Up-Pipes, S&B Cold Air Intake, Factory Head Studs.p |
#127
Turbo Swap
My question is. I want to swap to a single turbo set up, but I'm needing advice on which set up would match my drivetrain and accessories upgrades? I don't tow I would daily drive 150-200 miles per day I'm leaning towards a S366 which adds little HP & Less torque. I'm wanting to add EZ Lynk Tunes with the setup. Please Help Swapped Rear Differential 3:73 to 4:10 Upgraded Two Piece Driveshaft w/ Thicker Frame for Saddle ppBearing, ATS 5R110W Stage 2 Upgrade, 8" Pro Comp Stg.2 Lift, 38/13.50/20 M/T w/ 20x12 -44 offset Wheels, Fully ******d w/ Computer 150hp Tune. 4" Straight Exhaust, Factory Up-Pipes, S&B Cold Air Intake, Factory Head Studs.p 10-30-2014 04:02 PM |
#128
![]() Quote:
__________________
08' F350 6.4L EC/LB FX4 - long gone. 2017 F350 CCLB 6.7 SRW Platinum - 64/80 VGT Compound Setup, Exergy 10mm with 45% Inj, Warren Comp 6R, OUO Suspension, KING Shocks, FASS 140 LPFS, Lowered on 4800's, No Limit I/C & Goodies |
Thread Tools | |
Display Modes | |
