Sway Bar Endlinks Questions
Worstenemy453
Fredericksburg, Va
Hey man. I have an 02 F350 SRW. Looking at your sway bar end links and had a question that might help some other people too.
I will be leveled. What length is the best for this set-up. Also do you have a chart or breakdown of what length goes with what lift ?
NotStock
Tucson, AZ
The stock links are 12" long and are typically about an inch too long actually. So for a leveling kit you would usually want a 13" long link. However, its so close to stock that most people run a stock link.
Worstenemy453
Fredericksburg, Va
Im thinking about picking up your shackle lift for the front at 3" and then grabbing some of your sway bar end links to make sure i dont have any problems with the sway bar in the future.
