Your Aluminum IC band clamps to secure boots
JCart
Hey Fellas,
Finally got round to installing an IC and it’s the all aluminum series from a SD 7.3. Have the OEM ford blue accordion boot on hot side and Black ford accordion boot on passenger side. What band clamps are you guys using to secure these on the cooler end. All my other connections are with constant tension T bolt spring type band clamps. At the cooler end due to reduced room have just used standard T bolt band clamps just looking for more clamping power in confined area.
Thanks,
j
