Go Back   PowerStrokeArmy > Power Strokes > Excursions
Reply
Thread Tools Display Modes
  #11
Old 05-01-2014, 11:27 AM
94forddiesel's Avatar
94forddiesel 94forddiesel is offline
Sergeant
Member's Gallery
Default
If I was going for 800 horse id get a Trans from Brian and keep it auto but I miss shifting
__________________
2009 4x4 cclb f350 6.4 handshaker
2000 4x4 f350 7.3 handshaker 350hp 700 ft/lbs stock injectors stock turbo.
1994 4x4 rclb f350 7.3 handshaker idi 5 speed stripped down to the frame
  #12
Old 05-01-2014, 11:38 AM
rat49f6's Avatar
rat49f6 rat49f6 is offline
Major
Member's Gallery
Default
What about doing a ZF 5 it's quite a bit smaller and low and overdrive gears are comparable
Sent from my SGH-M919 using Xparent Green Tapatalk 2
  #13
Old 05-01-2014, 12:45 PM
Sergeant
Member's Gallery
Default
Not a bad idea and I have one of those sitting in the garage!
__________________
  #14
Old 12-23-2016, 12:36 PM
therabbittree therabbittree is offline
Private
Member's Gallery
Default
I have a G56 in my 2000 excursion with a 12v. It had stock floor with a nv4500. I added a removable floor hump when i did the G56. On powerstroke.org , and powerstroke nation there a few threads on excursions with manual trans etc
  #15
Old 12-29-2016, 01:59 PM
slowcoupe slowcoupe is offline
Lieutenant
Member's Gallery
Default
Good on you man. Doing something different. I swear when I have a family i'm buying a studded 6.0 ex doing a 15 front end conversion and tossing a zf6 into it. They are just so fun to drive. My 6.4 had a zf6 behind it, my 7.3 has one and I'm thinking about converting my 04 SD over to manual as well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
