Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #101
Old 01-11-2017, 12:14 AM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Dieseljay74 View Post
Let us know...hopefully this is a solid fix for everyone with this annoying issue
Sent from my SM-G930T using Tapatalk
Didn't change the filter, but I did try to drain it while running and nothing changed for me.
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #102
Old 01-11-2017, 08:57 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
how long do all of you guys let your lpfp run before you start the truck?
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #103
Old 01-12-2017, 09:32 AM
Jomax's Avatar
General
Member's Gallery
Default
When changing the filter?
__________________
  #104
Old 01-12-2017, 09:49 AM
04cr450's Avatar
04cr450 04cr450 is offline
Major
Member's Gallery
Default
The book says operate a koeo cycle 7 times? My truck is quiet under the hood only hearing the typical diesel sound.. something wrong for sure, I have also been around a hand full of 6.7'S and none of them sounded strange like this
__________________
16 250 tri-coat white, 22x12 AF satin black traxx with 325/50 terra g2, no limit goodies, flo pro exhaust, sct x4, recon smoked side and cab lights, retro solution led head and fog lights, icon 2.5" leveling kit with fox 2.0 shocks.
  #105
Old 01-12-2017, 10:20 AM
General
Member's Gallery
Default
Quote:
anytime you start it.. mine has a lil whine when I first turn the key.. I can hear/feel my lift pump gargle/prime and when that clears up and the whine goes away, I start the truck.. not sure if it matters though.. some have it.. some dont..
__________________
  #106
Old 01-12-2017, 11:42 AM
Jomax's Avatar
General
Member's Gallery
Default
Yeah I have that as well.
__________________
  #107
Old 02-25-2017, 09:41 AM
Spindrift Spindrift is offline
Lieutenant
Member's Gallery
Default
Well, I'll add my truck to the list except the whine is coming from the frame mounted filter and that makes me think it might be the pump. Does anyone have the whine coming from the lower filter? Coincidentally, the whine started when for the very first time I forgot to cycle the key after doing my regular fuel bowl draining exercise.
__________________
'12 F350 CC DRW KR
H&S tuned
Redwood 36FL
  #108
Old 02-26-2017, 02:30 AM
General
Member's Gallery
Default
Quote:
try cycling the key a dozen times till it times out and shuts off each time.. and make sure the drain and the filter housing itself is tight. lil bit of air will cause that!
__________________
  #109
Old 02-26-2017, 03:12 PM
Jomax's Avatar
General
Member's Gallery
Default
I have the whine from the lower filter.
__________________
  #110
Old 02-26-2017, 04:29 PM
BIG JUICE's Avatar
BIG JUICE BIG JUICE is offline
Lieutenant
Member's Gallery
Default
Reseat the filter housing. Had same issue last filter change, it went away
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
