Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 01-09-2017, 11:48 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
General
Member's Gallery
Default Help...Lost Most Oil and Died. Oil Leaking Around LPOP
Just need to bounce this off better versed fellow PSD folks.
Driving home last night in sub-zero temps, truck idled for a few minutes, (died when I tried to start it a couple times before it ran) and I left for home driving easy. Made it about 7-8 miles, started idling rough and died. I get out and the whole front of the engine bay is just coated with oil. Nothing on the top end or valley. Fan/belt/pullys/battery/CAC pipes, everything in front just coated. Had it towed home.
Today I went to Walmart and got a few big jugs of Delo, put 3.5 gallons in and tried to crank it. At first it didn't leak but as the HPO got filled up it started to run down under the main engine pulley, where the LPOP is. When I got under it with a light and camera, you can see it coming out of the front side of the pulley, not the block side.
Is this the LPOP seal gone out?
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
  #2
Old 01-09-2017, 11:55 AM
ToMang07's Avatar
General
Member's Gallery
Default
https://www.youtube.com/watch?v=PWgLTqctosA
__________________
  #3
Old 01-09-2017, 12:19 PM
ToMang07's Avatar
General
Member's Gallery
Default
Also the HPOP Res is full.
__________________
  #4
Old 01-09-2017, 12:33 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Sh!t. Won't really know till you take the lpop off and see
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #5
Old 01-09-2017, 12:35 PM
ToMang07's Avatar
General
Member's Gallery
Default
Quote:
Anywhere/anything else you can think of to cause it to leak from there?
__________________
  #6
Old 01-09-2017, 12:55 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Oil seal
__________________
  #7
Old 01-09-2017, 12:56 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Did you have a wear sleeve? Did something get wrapped around there to destroy the seal?
__________________
  #8
Old 01-09-2017, 12:57 PM
ToMang07's Avatar
General
Member's Gallery
Default
No idea on the sleeve, and nothing in aware of
__________________
  #9
Old 01-09-2017, 01:16 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Gonna have to take harmonic balancer off, then the lpop, then look at the oil seal to see what it looks like. Make sure the lpop is without damage. The seal seals on the harmonic balancer so you may need a wear sleeve now.
__________________
  #10
Old 01-09-2017, 03:34 PM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
If you use a wear sleeve, throw the harmonic balancer in the freezer to make it smaller, put the wear sleeve in the oven to make it bigger. Slide it on fast. Remember to wear good gloves.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
