Go Back   PowerStrokeArmy > Non - Specific > Tow-Rig
Reply
Thread Tools Display Modes
  #1
Old 06-29-2018, 03:56 PM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default Mirrors
I tow an enclosed gooseneck trailer.
Looking out and down the passenger side, the mirror neeeds to go out another 6" to have a perfect view. With the mirror fully extended, it's half of the trailer box.
The driver side is perfect.
Or is this a positioning issue because you are closer to the driver side mirror compared looking across to the passenger seat?
This issue is with both of my trucks. And both trucks have tow mirrors.
Anyone have this issue?
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #2
Old 06-29-2018, 05:08 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
The longer the trailer the wider the mirrors need to be in order to see all the way past the rear. Get some of those ugly mirror extensions. Lol
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #3
Old 06-29-2018, 05:42 PM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
I put '08 mirrors on my dually, that manually extend and I can see all the way down my 30' 5th wheel. but I don't know how wide it is, a car hauler may be wider. Jake I would say that what you said is only true if the mirror is not out far enough to begin with. Like a semi, if the mirror is far enough out, you will be able to sight down the whole trailer. On my obs I just say F it and mostly just use the spot mirror- but I also don't drive in any heavy traffic when pulling a trailer.
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
  #4
Old 06-29-2018, 06:15 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
Then why could you see better using the driver side vs the passenger side? I have the same view with my 34' GN and now with the 44' GN.
Billy T.
gnxtc2@aol.com
__________________
  #5
Old 06-30-2018, 07:38 AM
Sterling6.7's Avatar
Sterling6.7 Sterling6.7 is offline
Lieutenant
Member's Gallery
Default
If I understand the question correctly, is it possible that the rear axle of the truck is slightly angled, making the truck “crab”? Even the slightest amount could show up under these circumstances.
Everything “should” be the same measurement off of centerline.
__________________
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray
  #6
Old 06-30-2018, 08:20 AM
gnxtc2's Avatar
Major
Member's Gallery
Default
I know for a fact that the rear of my '97 is dead on balls straight as I assisted the alignment guy get the thrust angle to 0. Then the front was aligned.
The issue is that the passenger side mirror needs to extended another 6".
I drive my friend's 2000 F450 C&C with a utility body and it also has the same issue. When you look out the passenger mirror, you see half the body in the inner half of the mirror and the outer half down the body which is useless.
Billy T.
gnxtc2@aol.com
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
