Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #11
Old 08-13-2018, 11:38 AM
cbuttre835 cbuttre835 is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by old man dave View Post
Rockauto lists the 38 gallon rear tank as a tank for a 1988 F-250 351. Spectra Premium F26E. About $133 at Rockauto. More or less a bolt-in.
The 33 gallon tank is the Bronco one.
Cool. I had read elsewhere that the 88 *Bronco* 351 was the 38 gal., but I could only find the 33.
I wonder if the 38 has a flat enough place for a sump...???
__________________
But the conflict here is not between faith and science; it is between the competing faiths of theism and materialism, neither of which can claim to be proved by science. Modern physics has accelerated smack into the limits of the scientific method. It raises questions it cannot answer but that human beings cannot avoid -- matters of meaning and purpose. This is not a failure of science, just a recognition that measurement is not the only source of meaning.
  #12
Old 08-15-2018, 10:41 AM
Sergeant
Member's Gallery
Default
Thanks to 5_oh; tested a known good selector valve by applying + / - 12VDC to pins D and E on the selector - it swaps and holds position once DC is removed. The one on my truck is definitely not working - this valve makes a very distinct sound when operating.
Gonna disassemble the bad one - it's held together with clips and rivets - will advise on what the innards look like.
__________________
  #13
Old 08-17-2018, 04:42 PM
m j m j is offline
Major
Member's Gallery
Default
do not waste your time with bronco tanks. buy the 38gal tank from spectra that bolts in f26e / f26d .
__________________
Quote:
Originally Posted by Chvyrkr
BTS transmissions have the absolute top of the line hard parts and clutches, in every single one.....every once in a while that somebody like Mike O or Charles gets a different piece, because they've broken his normal piece.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
