08 f350 cclb
Shafer171
Michigan
I’ve decided that it’s time to let this one go. As you all know it’s been a rough road with the truck and my build. Nevertheless it is a good truck and deserves a good home. I bought the truck in 11 from Watts automotive in Utah, I am the second owner. It needs an engine, most all parts needed for the rebuild will be included in the sale. What’s included:
Clean block bored .20 over and decked
Heads from previous build-I’d put new valves springs and retainers on
2 cranks
Dynamic stage 1 regrined cam
Lifters,pushrods, rockers
Bpd water pump
2 Rae hpfp
New alternator
New starter
Rcd oil pan
No limit intake
No limit ic piping
Turbonetics 45mm gate
Rcd 71/59 turbos
8 injectors flow tested for build-have 1000 miles on them I’d have tested again
Rcd 30 over nozzles on injectors and stock nozzles
Midwest dual pump kit
Optima red top batteries
Mishimoto radiator
No limit intercooler
Marty’s a1000 lift pump
Elite fuel bowl
Dpc quad disk converter
Ats flex plate
Toyo mts have around 7000 miles on them
Pmf ladder bars -not installed yet
Isspro performax gauges boost, trans temp, egt
Mini max with gh tunes
******* dash daq with canned tunes
A new set of pistons, a cam, and rebuild the heads and its good to go(I would not run anything dynamic). You will need a new down pipe as well as I somehow lost it in my move. I need to get $13500 out of it but I will consider any reasonable offer. I will take any pics a potential buyer would like.
Shafer171
Michigan
Forgot to mention truck needs brakes all around and has a small spot of paint bubbling on the front bumper near the license plate mounting hole and a spot on the rear bumper on the corner.
Shafer171
Michigan
Some surface rust underneath. Truck is originally from out west, has been in Michigan since 2012, has rarely been out in the winter. Always garage kept and been torn down for the last two winters.
