How to make a 800 and up RWHP 7.3L
Status
Not open for further replies.
389sixpack
New Jersey
This thread is for sponsors/vendors (or users) to post a list of their dyno/race proven combination of parts and tunes to reach a good reliable 800 and up rwhp - 7.3L build.
The intent is giving users insight of what they need to buy and do to reach their RWHP goals.
It is not open for arguments!
389sixpack
New Jersey
From Diesel Innovations:
700-800rwhp **
4” down pipe 4” exhaust system
AFE stage II air intake
DI 4-6 position chip with appropriate tunes
DI Stage V B codes with 200% nozzles
Garrett GT(X)4202R turbo, IIS K31 71mm turbo- Nitrous(adjustable)
DI Regulated return kit
Fuelab or equivalent pump,(other pumps can be used just be aware they may not last.
Big oil, Stealth Stage 1(may work not proven) Stage 2 billet pump, Terminator dual pumps.
Headstuds
Upgraded valve springs
High strength push rods
Crower billet rods
Girdle-strongly recommended at this level but not required.
*Can be done on stock cam, but aftermarket cam and head work suggested to increase usable RPM band.
900-1000rwhp
Working on combination(will update later)
**Keep in mind these are approximate numbers to combinations that we have used and proven to work, I am sure there are other parts that can be used in place(call or ask)
389sixpack
New Jersey
Swamp's "all there is" HEUI Package ;)
_______________________________________________________________
intake/exh/connecting rod upgrades assumed
Hypermax H2e mounting kit (no turbo)
Swamp's BFH S400 Turbo (80mm+ available depending on rules &/or application)
Competition Fuel System (FueLab, 5/8" lines, reg return, etc)
Gen3 HPOP
Swamp's 400+cc hybrid injectors (nozzle determined by application)
H11 head studs/valve springs/pushrods
Swamp's tuned chip
Swamp's High Voltage & High Hz IDM
twin turbos &/or nitrous >1000rwhp
__________________
Swamp's Diesel Performance
Status
