Need single gauge pod pics
Zaairman
Wright City, MO
Hey guys,
I need ideas on how to mount a single gauge pod. Specifically, a HPOP gauge. I saw the steering wheel cover ones, but I'm wondering if they block your view at all...?
BlueWaffle
Grapevine, TX
doesn't block anything you need to see...
Oregon
If I ever need another gauge I'll be doing the steering wheel pod for sure! Have seen many of them and they look super good and they don't block anything!
As you can tell from above.
Zaairman
Wright City, MO
CSI, it looks like it slightly blocks the speedo above 90, and the lower part of the tach... that about right? If so, I can live with that.
Fox hunt
Stoke of Luck- Where did you get the steering wheel pod? Everyone else sells the ones up to 04 year and how did it fit?
Betarocker
Sea to Sky, BC
If you are worried about the gauge blocking anything from that angle, all you will see out of the windshield is the sky.
I have the column pod and it doesn't block anything, however the bezel pod does.
