#1
so last night i was bored and had uplaoded some new tunes... you all know what that means. had to test em out. well things went ary and turns out i bent a rod.merry xmas to me. i should have it back together tomorrow though.pretty cheap fix if you do the work yourself and stay stock.
#2
ouch!! luckily it wasnt more extensive damage.
__________________
01 CCSB slow as fnck!!!!! |
#3
I've bent one pushrod and broke another with no damage. I broke one rocker too.
__________________
2008 F350 CCLB, finally drives again. |
#4
at least you can fix it quick and cheap.
#5
You know its worth it in the end...how ya like the new tunes?
__________________
-Byron -2007 F-350 CCLB XLT FX4 ZF6 -01 Jetta ALH TDI EGR ******d and Malone 1.5 for now. |
#6
How high was it reved?
__________________
2015 F350 CCSB platinum Ngauge, S&B, 5"exhaust,OUO traction bars, OUO ala's 20x10 BMF wheels Toyo A/T tires are crap. Nitto G2 325/60/20 Wifes truck 2008 F-250 6.4 Auto, CC,SB,FX4, ******* tuning, Elite studs, Elite egr, Elite push rods, 71mm, Spearco Intercooler, cold side pipe,CFM, 4"down pipe,Custom 5" DP back exhuast Everything from Street Diesel Performance http://s601.photobucket.com/albums/t...0Ford%20F-250/ |
#7
not real sure how high i reved it.i was at about 75-80% throttle on the h&s hot damn tune.new rod is in and truck is running fine.**** happens when you play hard.im just glad it was a easy and cheap fix.new tunes are awesome. they added a performance tester so you can do 1/4 mi drags and itll track your time and speeds.also a 0-60 data log as well.pretty cool.
#8
I was just wondering what the cause was. A big tune is really no reason to bend a push rod? There should be a rev limiter at some point. I hit it all the time in my 6.0 at 4250rpms. Seven years and never an issue. I have the chromoly push rods in my truck, but never had an issue before or after.
__________________
#9
im chopping it up to a bad rod.its not a real big problem among the 6.4s. i think the limiter is around 48-49
#10
Happens to the best of us!
__________________
Jared Rice ___________________________________ One Up Offroad - Sales Director www.oneupoffroad.com www.ouostore.com - Now Live, Check It Out! Orders@oneupoffroad.com Mobile/Text - 503-780-3818 ___________________________________ Midwest Diesel & Auto - Sales Manager www.midwestdieselauto.com Jared@midwestdieselauto.com Mobile/Text - 217-691-3404 |
Thread Tools | |
Display Modes | |
