#1
Anyone have experience with this turbo?
Hearing good things... http://www.rivercitydiesel.com/index...mart&Itemid=54
__________________
2005 F250 CCSB FX4 LARIAT SCT w/ custom tunes from Gearhead Paint and body work by G Racing! SDRCM #244
#2
Personally, and this isn't a bash at RCD by any means but I would just stick with the Garrett Powermax, its a little smaller but its also $800 cheaper.
__________________
2008 F-250 CCSB Lariat, AFE Stage 2, 4 inch straight pipe, RCD 71mm Batmosphere, DashDAQ, SCT Livewire w/IDP, Traction bars, suspension stops 621 RWHP 9-27-12@IDP, 12.69@105mph 9-28-12 8180lbs. ![]() Elkton, MD
#3
Wonder how it lights compared to a stock Pmax...with say 190s
#4
BTW you guys forgive the newbieness here.
#5
Is it just a modified garret pmax?
A garret pmax is 64ish mm correct?
__________________
Cooper 04 CCSB 6.0 fx4 08 CCSB 6.4 4x4 03 SCLB ![]() Special thanks to: Logan Schneider at CenTex Diesel Performance www.centexdiesel.com 830-885-6500 |
#6
Id say it'll be a little slower, it would probably compare to a 64/70 non vgt.
#7
#8
Do you tow at all with the truck or drive any hills?
#9
Quote:
Spools like a powermax, barely any difference! Jared
__________________
2013 Black CCLB Platinum - SEMA Build ![]() 2013 White CCSB Platinum - 22 AF Delta, OUO/Icon 3.5" w/ OUO Trusses 2011 Teal CCSB Denali HD - FOR SALE 2010 Black CCLB - 821 on fuel. 2010 Black CCSB Harley - H&S, AFE, Titan, MBRP Duals - FOR SALE 2009 Red RCLB 6 Speed - OUO/Icon 3.5", SB 3600, 6" Stack - SOLD Jared Rice River City Diesel 309-822-0600 ext 1001 SDRCM # 369 |
#10
http://powerstrokearmy.com/forums/sh...251#post196251
Just saw this also lol. Or what about one of RCDs S300 kits? |
#11
I tow just a few times a year. 10k lbs max. No hills to speak of...
#12
On a street truck I would take a 68mm Powermax over a Nonvgt anyday. A couple guys have been running the 68mm with 155's. INSANE driveabiltiy for guys who tow alot. If I hadnt sold my 05, it would have gotten a 68pmx like Josh tried to talk me into in the first place..
#13
Quote:
![]() Are you dead set on your injector choice? I think it would run warm towing that weight with 190s. |
#14
Yes. really want to run a 190/75
#15
Where are you getting the 190's?
I don't have experience with the 68mm but I know the powermax was completely driveable. What ever happened to keeping this truck stock? ![]() A long time ago I put an 03 turbo on an 07 with industrial injection 190's with IDP tuning. Truck was able to tow 12k, daily drive, etc.... and ran 12.4's on nitrous. Oh, it was a CCLB on 35's and weighed 8200lbs.
__________________
2001 F250 CrewCab - 11.62 @ 115.76 2003 F350 Dually - Tow Bitch 410.392.3262 ![]() Elkton, Maryland SDRCM #1162 All fuel systems finalized and in stock. Give us a call. Kits ranging from $875-$1,400 depending on pump and engine. |
#16
![]() Injectors are from Dozers (Warren Diesel injectors) Thanks JJ! headgaskets are toast Marty. Cab's gotta come up anyway.... May be late Feb or so before this gets done. Just getting ducks in a row. |
#17
I found this that compares the stock turbo to the actual garret powermax, not the modded RCD unit. Does RCD even mod them from the powermax or are they just using that name?
The specs are as follows: Comp Wheel=stock IND is 56.8, p-max is 63.5 stock EXD is 81.6, p-max is 88 Turbine Wheel= stock IND is 72.5, p-max is 72.5 stock EXD is 64, p-max is 66.5 A/R is .90 on the powermax.
__________________
DamnKids Motorsports MIKE 2006 F-250 6.0 4x4 5R110 SC/SB Innovative Diesel Tuning 466/772 7/19/08 VEGISTROKED KCCO DKM ![]() |
#18
Jake Kelly @ KDP is running one with 225s IIRC - everyone that I know that has been in his truck says it runs awesome. Maybe give him or Matt a call for more info on it.
__________________
08' 6.4 EC/LB FX4 Daily Driver/Workstock puller/G-whip |
#19
What about surging with these larger vgt turbos? Can you tune all of the surging out?
#20
No problem man you will be very satisfied!
#21
Hell I'm learning with you.
#22
You will love the 68 we have it on my brothers truck he tows with it daily drives it with 205s. With tuning proper tuning i would not be scared to pull anything. and it is way stronger than a reg powermax. The 68 is not lagy at all.
__________________
all show no go. |
#23
How does drive pressure look with that charger? Wastegate recommended?
__________________
-JD 2009 F350 Stock Trans Absolute Performance |
#24
Does anyone have any hard data, Track times? Dyno numbers? I would be interested if they made significant more power than a power max.
#25
Matt,
Wanna chime in with what Jakes, truck made @ Scheids.. |
#26
Quote:
good info |
#27
Do they sell the stuff to upgrade the regular Powermax if someone already has one?
__________________
Performance Truck Products, G Racing, Diesel Innovations, Absolute Performance, No Limit Fabrication, Truck Source Diesel, Innovative Diesel, Strictly Diesel SDRCM #189 . |
#28
The drive pressure is pretty high with like 225s but with 205s we havent had any issue, I would think with 190s its probly about staright up.
#29
Quote:
These turbos are interesting to learn about. Sent from my SPH-D710 using Tapatalk
__________________
2001 Platinum Edition Mods: Changing everyday SDRCM#999 |
#30
Quote:
gare if you looking for a good turbo you will be impressed with the way it spools and the way it handles on the street. |
#31
Quote:
#32
#33
How would this turbo compare to the elite ssx??
__________________
2011 6.7 F350 - Dads 2009 6.4 F350 - Brothers 2007 6.0 F350 - Mine 1997 7.3 F250 - Farm Truck
#34
Man those things move some serious fuel.. whered you get them?
![]() Jared |
#35
By just looking at turbo specs the 68mm is bigger than the Elite ssx but they seem to be very similiar in design.
#36
Didn't he put down some numbers in the 600 range awhile back?
#37
i was just looking this stuff up an wondering the same things. not wanting to pull offtopic but how bad would running 155's or 185(190's) be with the stock charger really until the powermax would go on?
__________________
04 F250 - 6.UHOH. Studded and Deleted By PSE, Fueled by Warren and Aeromotive, and Tuned by Gearhead. 08 Tacoma Work truck. V6 Power nothing, Radio, AC, and 4x4 Thanks to G Racing, Dozers Diesel, and PSE |
#38
Is this just a wheel and housing change?
#39
is the shaft not a problem with the larger wheel?
Garrett
__________________
2003 F-250 6.0 XLT CCSB 4WD 5R110- time for the rebuild. twins?
1994 2500 12v RCLB 4WD 5spd- 382hp/1000tq gone but not forgotten 2000 GMC 2500 6.0 LQ4 4l80e RCLB 2wd- stock |
#40
the shaft in my opinion is fine with a bigger wheel, its the lack of tuning (surging) that kills the shaft from over speeding it.
Josh seems to have the tuning DOWN on that 68mm vgt . But time will tell, that vid is a smokey pig! Laying out some serious numbers though. I'd like to ride in one on the street
__________________
Greg - 2005 6Leaker |
#41
Not really that we've seen yet. Its not too much of a change fwiw. We have lots of guys with tons of miles on them too, and they are staying together just dandy!
Jared |
#42
Yeah he did but the truck only has 205s
#43
justttttt 205's. Lol. Tiny injectors right?
#44
Do you have any actual numbers?
#45
Just curious, how is it stronger than the regular one? I'm looking for a new turbo setup as well with my 190s..
__________________
2006 6.0- Compounds, dual pumps, 275/100's, sun coast. PSM |
#46
I just got back from a trip to the future (had to find out who won the superbowl so I could make my bet) and found this post you guys might find interesting...
Quote:
Good luck Gare, sounds like it is a pretty good turbo, and from what I've read and seen it seems something bigger than the regular powermax is needed specially for larger injectors
__________________
-Josh-
05 6leaker ocean liner studded, deleted, and tuned up 4" on 35's with a computer and stereo inside 00' Jetta TDI 5-speed, RC stage 2, Panzer plate, piped and deleted. |
#47
Quote:
#48
Yes we have a come dyno sheets laying around the shop.
#49
I meant that it pulls harder .
#50
well...not to be a killjoy gare but I'd think all bets are off on the stock "5r100" when you get north of 600. if i had the $ to do a trans when I did my turbo/injectors, i would have looked at the 68 with some 205's instead. might be something to think about.
__________________
aka Stroke of Luck 07 Shorty Reg Cab...compounds,hybrids, and everything else that goes with them. Cutting Edge Diesel Custom built compound setups, single turbo packages, injectors, as well as other bolt on parts. Shoot me a pm for any 6.0 performance needs. |
#51
Quote:
#52
what combo...190's and 68 or 190's and pmax?
#53
the 190's are plenty of fuel, i say a powermax is a waste to be honest if youre solely looking for power. Its going to be hard to get the 68mm vgt tuning right unless you have josh tune it. Unless you have the ability to have it live tuned.
#54
Which powermax the 68mm or the stocker?
__________________
04 F250 ARP studded, egr delete, Fass 95, ITP RR, IDP 58V tuned FICM, Powermax Turbo, gogo DD solenoid,Banks intercooler and intake,Tunes by TSD and Gearhead. |
#55
Here is a vid of Jake pulling his truck at the October pulls.
#56
Pretty sure theres only one powermax, the 63.5 made and sold by garret... that is unless RCD takes a powermax and modifies it into a 68mm which is possible but then its not a powermax anymore its just a 68mm vgt turbo.
#57
ah ok! my bad! thanks for clarification!
#58
No problem i wasnt very clear in my post lol
#59
Leaning towards 190s and a 68 with live tuning.
#60
Quote:
FWIW, isnt a powermax a 65mm? JW Jared |
#61
Eric can tune the 68 powermax also. Josh had sent the info to eric a while back for guys running eric's tuning that want to run the 68mm powermax.
__________________
2004 F-350 SC FX4, Dakota Digital gauges, insight CS, SCT, tuned FICM(ID), AFE, No Limit, spearco intercooler, water injection, FASS, Fuelab, Hellmann's sump, regulated return, Hypermax o-ringed heads, ARP's, Casserly 190 75% injectors, MTW billet hybrid turbo, amsoil oil by-pass, suncoast trans w/billet input future mods: aftermarket exhaust manifolds, ported intake manifold, Dieselsite's adrenaline HO HPOP, MTW billet stage3 and better built trans 501.1hp 847.7tq |
#62
Quote:
Jared |
#63
jared...is the 68 drop in or does it need a new pedestal?
#64
Quote:
Jared |
#65
pm coming at your face
#66
#67
eric tuned my 68mm vgt years ago. he has no problem tuning them. Not sure how much different this charger is than the Vgt HO that i had but i could never even think about towing a gooseneck. Im not trying to bash but i remember rcd telling people that they could tow easily with a 66mm non vgt. Is this one of those times? Thats alot of wheel to turn. Again im not trying to start something but before people go and spend 2500 on a turbo, they need to know exactly what they are getting.
#68
Quote:
__________________
Nate, 06 F350 w/96k miles Nate Built Turbo, Nate Built Oil Cooler Delete, Renegade Diesel 190/100 injectors, Nate Built Fuel System, Nate Built Ported Intake Manifold, and some other stuff..... MAD TURBO WERKS R&D SAP DIESEL BULLET PROOF DIESEL |
#69
Quote:
This turbocharger is a local favorite, and we have TONS of them out and moving, they are just getting popular wide scale, mainly because outside of the website, Josh doesnt do much advertising up till now. Thats what I'm here for.. Ive driven many 68mm trucks, and they are street monsters. I've got quite a few of my personal customers running 155's with a 68mm and having amazing towing. There are also quite a few gentlemen out there running 68mm's with 180's and towing, and they love it. Then you get guys like Jake Kelly, 205's with a 68mm.. and still towing. Kid has definitely got balls, but he says its possible to tow, and he does it. That says something right there. I dont think I would personally do it, but I'm a sissy about that kind of stuff ![]() Josh's modded powermax is a great idea, that is a very respectable friendly mannered charger for universal use. I for one, wouldnt be afraid to hop in a truck with a 68mm & 180's and deliver a load of hay just like I do with my truck with tow powers and 110's.. Thanks! Jared |
#70
Jared, how is the throttle response/lag with the 68mm powermax with like a set of 190/75's compared to a 64/71/70 with 190/75's? Just curious cause my 64/71/70 with my casserly 190/75's run pretty good without too much lag.
#71
Great example. My 05 I sold about 3 months back was a 64/71 .70 gated with 190/75%'s. My good friend Kyle had an IDENTICAL regular cab as mine (different color only). Daily driving Kyle's truck was a BLAST. Lit about like a stock truck compared to mine, although in a race, Kyle pulled on me early, but top end power was in my favor. Mind you both trucks had ported heads, valvesprings, cam, built trans, ult converters. IDENTICAL trucks. For driveability, 68mm hands down!
#72
So your 05 6L setup was like mine and your buddy's truck had the 68mm powermax. I like how my 64mm pulls on the top end...not sure if i'd sacrafice losing some topend power for a little more response. Do you think it'd be worth it Jared?
#73
I know mine turned really hard up top. But I think the cam attributed to it heavily. Honestly, if I get another 6.0, it will get a 68mm PMaxx & 185's, hands down. The guy who hauls grain for me in the fall is getting ready to do the same set up. Its just the perfect street truck combination.
Jared |
#74
Thanks for the info jared. How do you think both of them will differ Hp wise with 190/75's? Do you think the 68mm powermax and a 64/71/70 will be in the same ball park hp wise?
#75
Sounds like it may be the hybrid 238 injector/38r turbo combo of the 6.0 world.
#76
Quote:
![]() Jared |
#77
Id think pretty similar numbers would be achieved. Im sure the power curve's would be very very different though!
#78
Quote:
#79
What do you consider "in check" I know my ssx (64mm) would cruise around 900-1000 at 65 unloaded
__________________
05 CCSB -12.7@104- 611 on the rollers-fuel only |
#80
I mean the egt temps wouldnt get over 1,300 when towing with 205s, But the truck was in a tow tune that was built specificly for his truck.
#81
I tow with 225s and a 66mm non vgt... It's doable, you just have to watch the gauges and have a tune with a lot of fuel pulled out, however, I wouldn't recommend it to anyone as a good combo to tow with. I haven't played with large vgts so I don't really know how well they light, but I would still think there would be lag issues with a turbo that size. It definitely sounds like it would be a nasty street setup though
#82
I think I need one here to test
![]() I honestly liked my vgt ho but egts were high in every tow tune. When I talk towing though im not talking about a little boat or anything light. I was traveling a lot at the time racing motocross all over and i couldnt hook up to my trailer due to not being able to keep egts down. Without the trailer i would hit 1200 up hill with the converter locked. Non vgt seems to keep egts in check better. What are the specs on the wheels? |
#83
Quote:
How many of you that I havent already spoken to are interested in modded powermax turbochargers. I have an extreme excess of 04.5-07 powermax's on my warehouse shelves right now.. Who wants to help me move them? If I get enough interest maybe we can get a discounted price going across the board! Jared |
#84
How much discount are we talking? I'd be interested
#85
Is there any concern about the turbo shaft with the added weight of the larger wheels?
It's a 63.5mm Last edited by Mdub707; 12-30-2011 at 03:16 PM. |
#86
I ran 3 different modded vgt turbos, and they just didn't last(best was 20k before grenading).
#87
Lets get a few more people and we'll talk pricing. Im willing to sweet talk Josh if we can get enough people modivated. I think 5 is a fair number.
#88
I'd be interested if the price is right. Tax return season is just around the corner.
#89
i would get a different pedestal for the right discounted price.
#90
Quote:
.....if the price is right im interested!
__________________
2006 F350 SRW 4X4 SOLD SCT Livewire with gearhead tunes Egr delete Sinister diesel coolant filter 8k HIDs 4" mbrp tinted all the way around smoked cab lights |
#91
you wont need a different pedistal. The 68mm powermax bolts right to the factory pedistal.
#92
I have early 04 and he said they have a bunch of 04.5-07 turbos only reason I'd swap pedestals.
#93
okay gotcha. Mine is an early '04 also. Just ask and see if they can do one with an '03-early '04 exhaust housing.
#94
Yea if they would sale price an 03-04.5 with the rest I'd do it or if I was paying normal price. But if the sale was good enough to cover pedestal change then swap would be worth it.
#95
Pedistals are dirt cheap....even from the dealer...
#96
I think my dealer charged me $225 for one.
#97
Yikes...
I bought an '05 pedistal for like $130.00 CANADIAN....which is about $5.99 US |
#98
Yeah, I hate my local dealer. They also wanted $1500 to swap turbos on my 6.4
#99
Why did you switch to the 03 pedestil? I never did ask.
#100
Either that or I'm sure I can find a part out or a yard around here than can get one for me.
#101
no need to buy a pedestal..... the two bolts, downpipe, and uppipes hold just fine. You think one bolt is going to make a big difference.
#102
I have a new style pedestal in stock for sale I'll let it go for 75 shipped
#103
That's what I'm talking about. I would even be willing to bet that provided the turbo was properly placed on the pedastal, that one bolt would keep it there since it has the weight/support of the down pipe and up-pipe. I wouldnt worry about the difference in pedastals IMO.
#104
pssssssshhhh...i haven't had all three bolts on my turbo for over a year now. no problems.
#105
I see what yall are saying but with stuff like this below i wouldnt mind getting one just to have the 03 with the turbo
#106
heck...my turbo isn't even bolted to my pedistal...it just sits on it haha
#107
You goofy guys and your lack of bolts, haha. My first 05 had one of the first 03 Powermax's on it with 2 bolts, worked like a charm! Haha.
I have A LOT of the 04.5-07 turbo's ready for modification, I'm just shorter stocked on 03-04's but we do have a few still. I will discuss terms for the 68mm turbo's tomorrow with the boss and see if we can work something out for a group deal for them!
#108
Ok,
Started a new thread to stop the derail of Garrett's. For those interested in getting on the buy in bandwagon, Simply post on the other thread with your information about your truck and we'll get a price together! Jared |
#109
What is the warranty on these?
#110
How is back pressure with these chargers?
#111
The place I bought the powermax from sent me the wrong turbo so I had to get an 03 pedestal.
#112
They didnt offer to make it right?!
#113
Good thing Garrett started this thread...........
__________________
97 F-350, With a 7.3L Diesel. FF 300/200, Billet HX55, Stealth twins, AirDog2, 3:55 Gears, Lockers front and back, ZF6 tranny, ARP HS, 910 VS, stock 6.0 IC with DIY 3.5" IC pipes, And more.... 98% of the teenage population does, will try or has tried smoking pot. If you're one of the 2% who hasn't, copy & paste this into your signature. -MidnightBlade |
#114
can you spray this turbo or has anyone yet?
__________________
190cc MPD 6.0 single Kit kmc rockstars 4 link |
#115
you can spray anything lol
#116
Prob better gate it
__________________
2012 6.7, 2.5 leveling kit 325/50/22 wildpeak A/T on 22 incubus nemis/ AMP steps... the rest is stock
08 Reg cab,11.23@124 on fuel 7100 lbs . SDRCM #21 |
#117
haha
#118
is the back pressure in the powermax is much higher then say a 64mm
#119
my back pressure with 190/75's and the 64/71/70 stays 1:1 all the way to nearly 40psi.
#120
We havent seen anything outrageous. Things are pretty easy to keep under control.
#121
He did, I just have to place an order through him again to get it lol. I needed the turbo to make the diesel drags that weekend or I would've waited for the 04.5 and up turbo to come.
#122
Has anyone tried spraying it even a small shot???
#123
My buddy Kyle sprays the ever living hell out of his with 180's.. He has no common sense
![]() Somehow, over a year and no popped turbo yet. I think thats a testament! Lol |
#124
I think Gare just needs to pull the trigger on one of these and give us a review!
#125
+2 dustball
#126
so if he has been spraying it, what did he put down on the dyno, or has he had it on the track?
#127
Quote:
![]() Hopefully we can throw another truck with spray on the dyno here soon, or we can talk kyle into putting his on. Or maybe.. Garrett or Danny want to spray theirs
#128
just thinking out loud here. if 600 on fuel is possible with this turbo, its kinda looking like this turbo can support close to 700HP on juice?? kinda sounds like a time bomb to me but there again just thinking out loud
#129
I would think the drive pressures would be WAY high if spray were added. They are already high IMO with just fuel from large injectors, so I would agree that it sounds like a ticking time bomb. JMO and thinking out loud.
#130
If you planned on spraying a lot I dont think it'd be too much hastle to throw an external gate into the mix.
#131
i like this turbo lol
#132
#133
Welcome Brent,
I had no idea you finally made it over from PSN Brents truck + Tylers Hybrids + 68PMX =
#134
Welcome aboard! I take it you ditched the S400?
#135
how large injectors if you don't mind me asking? :P
#136
Dont hold me to it.. but I believe they are 295cc Hybrids correct Brent?
#137
Quote:
#138
We do offer a good price to modify your powermax into our modded one, and we have another design in the works, stay posted!
#139
How much do y'all offer on the modification to an existing?
#140
PM Sent!
#141
We've done testing with the 68mm and have dialed it in well. We'll be doing more drivability tuning with various injectors in the next few weeks.
__________________
Innovative Diesel Performance. 1-410-620-3020 www.innovativediesel.com We are a SCT Custom Tuning Dealer for all Ford products. IDP thrives on carrying only the best parts and great customer service. TuneMyDiesel.com |
#142
Could you run this Turbo with 175 injectors with stock nozzels?
#143
Quote:
Sweet! ![]() . |
#144
Quote:
#145
Quote:
Jared |
#146
The powermax is still on the truck..not for long tho.. putting a 2.6 s400 on here soon.
#147
If anyone is still interested in these things as a buy in they are still available, closing down the PSA buy in on friday.
#148
What's the price? Never heard any details and never saw the thread that was suppose to be started.
#149
Quote:
![]() http://powerstrokearmy.com/forums/sh...ad.php?t=11063 |
#150
Thanks man.
#151
For those that were interested in the 68mm Powermax our PSA Buy in ends today at 5pm central. Make sure you post on the link if your interested! Very good pricing
#152
How does the exhaust side on 68mm PMAX compare to the standard powermax?
| Thread Tools | |
| Display Modes | |
