neverkickn
I have a good bit of lag in the file named 60t and I have a hard time getting the charger to come up on boost from any cruising speed without a downshift. Both logs are recorded from a stop all the way up to the od shift with the pedal to the floor.
The injectors are 160's with stock nozzles and the charger is a d66 with a 1.0 non gated turbine housing.
To me it looks like I have an aweful lot of PW and the icp isn't coming in fast enough or high enough.
Any insight on what might be going on would be very much appreciated. I can get any other values need, just let me know.
