crank sensor
DEEZUZ
NO PUKESTERS
NWI
take a 90 degree grinder with a small wire brush end and brush all around it to knock off any rust. do anything but twist it.. wiggle wiggle wiggle. when you get it out, take the wire brush to the sealing surface... it has to be perfect or itll toss cam codes and die
DEEZUZ
NO PUKESTERS
NWI
oh crap, sorry.... CRANK you said... no, crank sensor is much much easier than cam. sorry.
no it does not, just use 1/4 drive swivel
bad moose
Valley Center KS
I went in from underneath and the front of the engine. But I had a lift. I did not remove anything. Like stated before 1/4 inch long ass extension and swivel. Patience is the key.
