Need help with Fuel system
vcassens
Godfrey,il
Ok so my fuel pump is about done and I will be replacing everything from the tank to the engine so where is the best place to get a package deal I need the fuel pump (air dog or fass) a sump and all the lines to feed to the back and front of the heads. So where is the best place to get this from? and what do you guys recommend for the pump. I will also be getting a fuel pressure gauge and searing column pod. Thanks in advance and any vendors that want to send me a pm with pricing please do I wold like to make a one stop shop thanks Vincent
Pizza pig
MD
nothing is drop in when youre looking to do this kind of custom... Ditch the idea of the airdog... from my experiences these standalone pumps are a waste
completely remove the stock fuel supply line
fuel sump
1/2" (-8an) line from the sump to
custom CAT/Baldwin fuel filters/water separator
- (2) Baldwin FB1311 Fuel Filter Bases
- (1) Cat Filter 1R-0750
- (1) Baldwin water/sep BF1212
1/2" (-8an) line from filter to an aeromotive fuel pump
- Aeromotive a1000 regular or marine grade
1/2" (-8an) line from aeromotive pump up to the engine bay to a y block
(2) 3/8" (-6an) lines to the front or back of the heads
(2) 3/8" (-6an) lines from the front or back of the heads to each port on the regulator
(1) return line off the regulator to the stock return line using a an to hardline adapter (this is sufficient)
let me know if there are any questions you may have
vcassens
Godfrey,il
fuel sump
Thank you for the info. Do you no what the 90 degree fitting are that go into the cylinder head I am not apposed to doing it this way I have access to the hose crimper at work so that wold not be a problem
Pizza pig
MD
yes all 4 ports on the heads should have 90* sealed fittings! that was just a basic list not including what hose ends to use etc. Do you have access to fittings as well? I would assume since you have a crimper at work, I would prefer to use steel crimped over aluminum reusable fittings but I dont have access to a crimper
Extended Power
Damn....things are so much easier when the heads are pulled off...
The fittings are a metric size, and are not tapered, so a regular JIC or NPT fitting will not fit.
One of the first fuel systems I did, (Before pulling the engine) used the stock bolts in the heads, but I cut the 1/4" tubing, and adapted the hose to the tubing.
Since then...when I had the heads pulled, I had the ports drilled out and tapped for NPT fitiings.....way easier to get parts for.
Pizza pig
MD
yes you are correct, parker sells steel m12x1.5 to -6an swivel o-ringed adapters... earls sells them too in aluminum.
vcassens
Godfrey,il
Thanks for the info does anyone have pics of how they set up there fuel filters? I wold like to see how everyone has mounted them thanks
Pizza pig
MD
This is the truck I used my plans for
Pizza pig
MD
adiesel.com for the baldwin filters and bases
I'd get all your fittings from anfittingsdirect.com (-an straights, -an unions, stainless braided line etc)
jegs (y block, hardline to -an fittings, 90* metric to -an fittings, regulator, orb to an fittings)
faster6.0
We can make any type lines/fittings needed, we are Parker direct as well as other fitting companies. Let us know if we can make you a custom fuel system Taylored to your needs.
Pizza pig
MD
fuel system and ficm tuning... i think I need a break from the forums lately... same **** different day
vcassens
Godfrey,il
Please pm me a price on one I want to feed the front and back of the heads the one I saw like this was using an air dog 2 with no return from the motor at least I think that was how it was set up because it would rerun from the pump. Does this sound right to you guys? I soul also like a sump for the tank so if you guys could figure a price that would be awesome thanks
Pizza pig
MD
feeding the back of the heads and the front of the heads is USELESS, it doesnt solve the deadhead problem and still doesnt keep equal pressure to both heads.
The return from the pump is only a portion of the fuel, its the foam (filtered air from the fuel) that goes back to the tank.
Have JJ build you something with and aeromotive a1000 and a regulated return.
vcassens
Godfrey,il
What is so much better than the aeromotive pump vs the air dog the main reason I like the air dog is that the filters and pump is all one unit and everyone that I have heard have a failure got it resolved quickly what kind of warranty does the a1000 have
