complete 08 6.4l engine.
stuckinmud
Just received an 08 6.4l with everything from motor mounts to wire harnesses and even the pumps. It was replaced with a Ford drop in. All they had to do was make electrical connections and fluid lines.
It was running bad, suspect a cracked piston.
As is on pallet 2500.00 plus the ride from Michigan
Or in the next week I will be opening it up and going the part route.
stuckinmud
Haven't had time to pull it apart.. just going to move it complete as of now. I can say the turbo shafts have no play.
Its complete here are more pics.
If your tire kicking don't waste our time if your seriously interested PM your best offer.
stuckinmud
Just opened it up.
As suspected it cracked one piston.
All 8 cylinders are perfect and un-scored.
No damage to the heads, they look perfect.
Headgaskets were not compromised either.
Would still like to sell it all as a whole-
Or as a short block and I'll part out various parts.
The other option is I will part it out entirely.. its more work but if enough people take the parts I am good with it.
So if one of he options work for you send a PM so I can weigh it out.
Thanks!
stuckinmud
LOL I'll let you take that up with my buddy... but knowing him everything is for sale for the right price and looking at that pic..that's only one of his boxes.. oh the toys I wish we would have kept around..
Jmoore1225
Still parting this out, may need a high pressure turbo, may need a whole lot more :-/
stuckinmud
Ok decided to just part it out..
PM if you need something..
I'll get a list and prices together shortly
stuckinmud
Parts and more parts bump for the day
Also have Fan clutch w/ fan
extra Brand new EGR coolers
Glow plug module
A/C comp with lines
HPFP
The injectors are now available
Starter
tensioner and pulleys
Power steering pump
Up pipes
new EBP sensor and tube
Engine Harness
Injector harness's
Glow plug Harness's
Fuel canister
Fuel cooler
Intake manifold
Heads
Block
Front cover
Oil cooler lol but who would want that
Exh manifolds
and more...
