Blowby
- Joined
- May 22, 2011
- Messages
- 1,532
- Reaction score
- 0
Just wanted to post the transition from my first attempt to deliver water to the race truck.
I kept thinking the 200/250 pumps would really work at high boost but with my data logging the EGT's it was a disappointing failure.
I was thinking two pumps, with each feeding 2 jets small in size, would keep the atomization to a level that would show lower temps.
It was a slight success if I used a 30% mix of methanol but I did not wanted to rely on a "best guess" to control the ignition of my fuel.
I also was not able to create a fine enough mist to eliminate condensation on the tube wall which would then form larger droplets and drip into the center cylinders at a higher concentration.
Next step was to pick up a pump that will produce over 1000 psi which I traded Steve at TTS for prototyping stuff last year.
I then decided that to eliminate any high amp draw on the electrical system I needed to separate with it's own battery.
Now to utilize the new capacity and recharge without anything to remember to turn off or on during the rounds of a racing event.
Now adding the charging pieces to the puzzle. Just need one switch and I'm done.
I did add an inline pressure pop off valve that will open form 90-250 psi based on the springs and shims I choose.
I doubled my safety with jets that have their own spring loaded shut off in the holders for added protection.
I'll soon find out if I will be able to control the pressure behind the jets I choose.
Pressure will change as the size changes and I can accomplish the control with the regulator (upper right) and the pressure gauge to verify psi.
Of course with the jets installed on the end of the lines while I spray to atmosphere.
