Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 05-12-2012, 06:59 PM
LiftedBlackHD LiftedBlackHD is offline
Sergeant
Member's Gallery
Default Why doesn't my high idle work?
It worked fine for a while and now it will not idle up. I think this happened when I added tunes but it's been so long I can't remember. Could the SCT custome tunes cause my high idle not to work?
__________________
2004 (12/03 build) F250 Super-Cab Long-Bed 6 Liter PSD 4x4 Harley Davidson Edition
Icon 8" lift, Fab-Tech dual steering stabilizer Kit ,20" KMC Rockstars (Black), 38x15.50" Toyo Open Country's M/T's, SCT Tuned by D.J., 05+ Intake Elbow
,Zoodad mod, High Idle Mod, 4" MBRP turbo back, CCV mod, Outlook monitor, Recon Led's, Dieselsite coolant filtration system, Cat ELC, Warn Premium Hubs, 6.4 Banjo Bolts,blue spring, welded shut egr cooler, scan guage 2
  #2
Old 05-12-2012, 07:28 PM
jbkingranch's Avatar
jbkingranch jbkingranch is offline
Sergeant
Member's Gallery
Default
Don't know it it's related but when I put my Extreme Street from ********** on mine a few weeks ago mine stop idling up. It would be nice for it to work cause it's still getting in the 30's up here in North Dakota at night and the truck warms up a lot faster with it.
__________________
2004 F-250 6.0
1996 F-250 7.3
  #3
Old 05-12-2012, 07:34 PM
03 tx pwr stroke's Avatar
03 tx pwr stroke 03 tx pwr stroke is offline
Major
Member's Gallery
Default
Have ya'll done the high idle switch mod? I did it on my truck and I use it quite a bit when outside temp drops.
__________________
Gulf Coast Powerstrokes
03 F250 6.0 CCSB Lariat FX4, 230k
Typical first mods....******d, studded, tuned, exhausted, not running...
  #4
Old 05-12-2012, 07:46 PM
Sergeant
Member's Gallery
Default
Quote:
That's what we're talking about.
__________________
  #5
Old 05-12-2012, 08:05 PM
Major
Member's Gallery
Default
Oh. Sorry.
__________________
  #6
Old 05-12-2012, 11:02 PM
06-sixoh's Avatar
06-sixoh 06-sixoh is offline
Major
Member's Gallery
Default
I dont think its related at all. Make sure all of your relays and fuses are secure in the junction box. Its behind the glove box. When the high idle doent work, does the light come on for your switch? If it does, your are getting power to your aux switch.
__________________
2016 Magnetic Grey F250 FX4 Lariat CCSB
Lariat Ultimate, Chrome Package,
NL StageII Intake, EZLynk w/ SOTF
Carrying Civilian
  #7
Old 05-13-2012, 01:06 AM
Sergeant
Member's Gallery
Default
I haven't done any mods to mine for high idle. I just know when I crank it up and it's cold out it will idle itself up to around 900rpm until its get to operating temp then goes back down to 650. If I have run the truck, shut it off and crank up when the coolant temp is around 100 degrees it will only idle up to 750 then idle back down after getting to operating temp. When i tuned it with the SCT it stopped doing that. It stays around 650 all the time.
So for experimentation I detuned back to stock to see if it would idle up and it did. Coolant temp was 94 degrees, she held at 650 for just a minute and then idles up to 750. Cut the truck off, put my custom tune back on again at it stays at 650 all the time. I know the tune is set for 625 rpm idle so I think my tune is keeping it idled down.
__________________
2004 F-250 6.0
1996 F-250 7.3
  #8
Old 05-13-2012, 12:55 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Major
Member's Gallery
Default
So none of yall have done the high idle "mod" and your relying on the truck work like the factory designed?
__________________
RANDY
2006 F250 CCSB 6.0 PSDFX4 LARIAT
SCTX2 CUSTOM TUNES, ISSPRO FUEL,AIR, FIRE,AND TRANNY
PRETTY MUCH STOCK
  #9
Old 05-13-2012, 06:11 PM
Sergeant
Member's Gallery
Default
Yes air. At least I am. Where do I get the high idle mod from? I don't have any relays behind my glovebox.
__________________
2004 F-250 6.0
1996 F-250 7.3
  #10
Sergeant
Member's Gallery
Default
Yes Sir...
Fat fingered from iPhone
__________________
2004 F-250 6.0
1996 F-250 7.3
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
