Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 06-01-2012, 02:21 PM
JoeDaddy's Avatar
JoeDaddy JoeDaddy is offline
Colonel
Member's Gallery
Default strength of D44 straight axle vs D50 ttb.
What's the diffs in strength?
__________________
Diesel Whisperer.
OBS ADDICT.
  #2
Old 06-01-2012, 03:17 PM
Worstenemy453's Avatar
Worstenemy453 Worstenemy453 is offline
Colonel
Member's Gallery
Default
Dana 44 straight is close to a Dana 60.
Dana 44 HP
Quote:
8.5-Inch Ring Gear Diameter
1.31-Inch / 30-Spline Axle Shafts
1.38-Inch / 26-Spline Pinion
3.73 & Down / 3.92 & Up Carrier Break
Coil Spring / Radius Arm Setup (F-250's and 1977-1979 F-150 Super Cabs have leaf sprung Dana 44's)
5x5.5 Wheel Bolt Pattern on F-150's (F-250's are 8-lug)
Axle Width (unknown)
Cant find my info on the 60's at the moment. But if you throw a set of axle shafts in a 44 HP then it will be stronger than a Dana 60.
  #3
Old 06-01-2012, 03:57 PM
97BambiBasherPSD's Avatar
97BambiBasherPSD 97BambiBasherPSD is offline
Lieutenant
Member's Gallery
Default
What are you planning on doing? If its just an sas to get rid of the ttb then just throw it in there. If your making some serious power put bigger shafts in. Either way run a solid d44
Sent from my Pear phone using Tapatalk
__________________
97 7.3 5 speed F350 RCLB 250/200s, valair DD, 35s, fuel system and RR, 55psi on stock turbo and still praying, currently wrecked and waiting for revival
2004 6.0 CCLB DRW King Ranch egr ******, warren heavy tow trans, SCT 5015 with warren tunes, PTM 05 front end with harley grill
  #4
Old 06-01-2012, 07:33 PM
oneton's Avatar
oneton oneton is offline
Sergeant
Member's Gallery
Default
what year axle?if 78-79 f150,wont work.
f250,wont work either without major suspension mods.spring pad width 32.5 obs trucks are 36.5 width
if a 2wd obs,a f150 front will bolt in with minor mods
__________________
96 f350 4wd auto cclb 6637,5in exh,6pos,more to come
97 f350 4wd auto(built) rclb afe stage2,5in exh,38 radials
  #5
Old 06-01-2012, 08:24 PM
strokethis_06's Avatar
strokethis_06 strokethis_06 is offline
Lieutenant
Member's Gallery
Default
Actually 78-79 is the sas of choice because the driverside tube is longer. Hence more room for spring perch. You just have to weld your own perches on.
Sent from my SAMSUNG-SGH-I897 using Tapatalk 2
  #6
Old 06-01-2012, 08:30 PM
JoeDaddy's Avatar
Colonel
Member's Gallery
Default
Right, it'll work for sure. I'm just thinking out loud b4 I waste any time. You can buy solid 44's for peanuts and have a coil sprung 2wd conversion for cheap.
__________________
Diesel Whisperer.
OBS ADDICT.
  #7
Old 06-01-2012, 08:41 PM
Lieutenant
Member's Gallery
Default
We just finished a coil sprung 60 in my 79 and a coil 44 in my buddies 86.
  #8
Old 06-01-2012, 09:23 PM
JoeDaddy's Avatar
Colonel
Member's Gallery
Default
Link? Or pics?
__________________
Diesel Whisperer.
OBS ADDICT.
  #9
Old 06-02-2012, 06:05 PM
Lieutenant
Member's Gallery
Default
I have them on a camera but my computer is down right now. Using my phone for internet. Lol.
  #10
Old 06-02-2012, 06:08 PM
Lieutenant
Member's Gallery
Default
I have a couple on my phone. Not sure how to post them.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
