Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 08-05-2012, 02:44 PM
TheReelMuhcoy's Avatar
TheReelMuhcoy TheReelMuhcoy is offline
Lieutenant
Member's Gallery
Default Dual alternator kit
Anyone know where I can get a list of parts for the dual alt kit? I am thinking of using the kit as a relocation kit to make room for my intake pipes for my 6.4 turbo's.
__________________
-Jon
'03 F-350 CCLB, 6.0 with 6.4 compound turbo's 488HP/835TQ
Work truck "Frankenstein"- 03 f350 SRW - EGR blocked & towing 7500lbs daily.
2007 F350 Dually SuperCab&Chassis - SOLD
Face Book me- http://https://www.facebook.com/jon.yochum.9
  #2
Old 08-05-2012, 08:55 PM
Lieutenant
Member's Gallery
Default
Those of you who are running dual alternators... do both alts run off the same belt? if so this may mess with my idea of running the lower alt as my main alt. Any thoughts?
__________________
-Jon
  #3
Old 08-05-2012, 09:15 PM
streetglide's Avatar
streetglide streetglide is offline
Sergeant
Member's Gallery
Default
Different belts
__________________
1997 CCSB 4x4 . 4" lift , 18" Chrome Weld Evo's, 35" ATZ 4.10 . Swamps 250/100 Hybrids , Modded H2E 71/76 19cm . Arp Studs , Cometics , Electric Regulated Fuel , Comp 910's , Smith Bro pushrods , Swamps tunes , 7.3 Intercooler
  #4
Old 08-05-2012, 11:26 PM
CCRICE's Avatar
CCRICE CCRICE is offline
Sergeant
Member's Gallery
Default
I don't see why if you re mount your alt somewhere else as long as it can still hold tension on the belt it would matter.. If you run it low you would still have the same slack as if it was up top provided it's mounted right.. I dunno it might take some redneck ingenuity but i don't see why it can't be done.
__________________
Chris
07 F250 CC SB
RCD Egr ******
4in exhaust
SCT Livewire with custom tunes from Matt @ ********.
  #5
Old 08-06-2012, 06:51 AM
Mdub707's Avatar
Mdub707 Mdub707 is offline
General
Member's Gallery
Default
The PCM randomly selects which alternator to use at the time, I don't quite understand it, but I'm not sure you can just use one or the other. I know guys who have tried going from dual alts to singles and the consensus was you basically need to do the swap in the Ford parking lot and have the PCM reprogrammed right after. Maybe there's a different way to do it now, but not sure.
The dual alt setups has two alts (obviously) two tensioners, two belts... etc... it's a mess in there.
__________________
MIKE
2006 F-250 6.0 4x4 5R110 SC/SB
CED T4/S362FMW/********** Diesel/PHP
VEGISTROKED
495/906
KCCO
  #6
Old 08-06-2012, 12:51 PM
FaSSt9602's Avatar
FaSSt9602 FaSSt9602 is offline
Lieutenant
Member's Gallery
Default
If he is just using the bracket to mount a single then it shouldn't matter, there is still only one alternator....but, being that they use a separate belt to run the second, I betting it won't work...
__________________
2006 F250 CCSB
Trying to figure out what to do next...
  #7
Old 08-06-2012, 01:04 PM
Zmann's Avatar
Zmann Zmann is offline
Colonel
Member's Gallery
Default
dual to single does not need a pcm reprogram there is a wire that needs cut
Dennis at Strictly has some info as He was messing with this
as far as single to duals ,, it shouldn't be to bad and I do not know if that would need a PCM flash?
  #8
Old 08-06-2012, 01:10 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
Quote:
Q14: How can I change the F-250/350/450/550 trucks with 6.0L diesel dual alternators to a single alternator?
A14: Refer to QVM Bulletin Q-91 for F-Series Super Duty with 6.0L diesel dual to single alternator conversions.
Single alternator to dual alternators conversion is not recommended.
PDF on wire mod dual to single https://www.fleet.ford.com/truckbbas/non-html/Q91.pdf
  #9
Old 08-06-2012, 01:14 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
some info
http://www.powerstroke.org/forum/6-0...ternators.html
  #10
Old 08-06-2012, 01:33 PM
smokinstroker's Avatar
smokinstroker smokinstroker is offline
Colonel
Member's Gallery
Default
Guys y'all are making this so much more complicated than it needs. My truck went from a single on top, down to a single under the manifold In a weekend, no programming or anything.
  #11
Old 08-06-2012, 01:56 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
Quote:
Originally Posted by smokinstroker View Post
Guys y'all are making this so much more complicated than it needs..
UHHM
That's how We roll
  #12
Old 08-06-2012, 07:43 PM
Lieutenant
Member's Gallery
Default
Now I am completely lost. I have seen that QVM bulletin before but it says nothing about what parts are required for the 2nd alt.
What I need is to completely remove the upper alternator and install one in the lower location. Is this even possible? I just noticed that the belt that drives the upper alt also drives the AC compressor and some other things. How do I get around this?
Jon
__________________
-Jon
  #13
Old 08-06-2012, 08:01 PM
El chupacabra's Avatar
El chupacabra El chupacabra is offline
Lieutenant
Member's Gallery
Default
Jon
Make a bracket and put n a dummy pulley.
-Jake-
__________________
-Jake-
  #14
Old 08-06-2012, 08:08 PM
CCRICE's Avatar
Sergeant
Member's Gallery
Default
What i was getting at is you take the alt, move it to the bottom.. As long as you position it right you will use the same slack from the belt. I can't see a reason why that would create an issue. As long as you maintain the tension you should be good in my eye. Correct me if I'm wrong.
__________________
Chris
07 F250 CC SB
RCD Egr ******
4in exhaust
  #15
Old 08-06-2012, 08:14 PM
Mdub707's Avatar
General
Member's Gallery
Default
The upper and lower alternators use different belts, how does one just move it to the other location without buying all of the related hardware, and then how do you keep the belt tight with the original alt gone? Putting a dummy pully in there doesn't gain you much room
__________________
MIKE
VEGISTROKED
495/906
KCCO
  #16
Old 08-06-2012, 08:40 PM
Lieutenant
Member's Gallery
Default
Well from what I can tell the OEM alt designed to go in the lower position has a different groove count than the upper one so unless I can swap pullies that won't work.
Making a mounting plate and attaching a pulley would eliminate the bulkey alternator body in the way, I am still limited by the pulley but that would make a lot more room for me to angle the intake past where the alt would be...
__________________
-Jon
  #17
Old 08-06-2012, 09:26 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
Honda generator in the bed ,, problem solved
  #18
Old 08-07-2012, 06:41 AM
Mdub707's Avatar
General
Member's Gallery
Default
I've got quite a few pics of my dual alt setup on and off the truck, maybe that will help answer some questions.
Also for anyone who has dual alts, you can remove that crimped CAC tube and put the one meant for the single alt trucks in without issue, I've swapped mine out after this picture was taken.
Some of the hardware used to mount the second alt:
Another of the "crimped CAC tube"
__________________
MIKE
VEGISTROKED
495/906
KCCO
  #19
Old 08-07-2012, 11:06 AM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Major
Member's Gallery
Default
Talk to shawn, ivan or matt. They I believe have used the dual alt brackets to mount the single in the lower position. Kind of a pre resq. For twins I though.
__________________
RANDY
2006 F250 CCSB 6.0 PSDFX4 LARIAT
SCTX2 CUSTOM TUNES, ISSPRO FUEL,AIR, FIRE,AND TRANNY
PRETTY MUCH STOCK
  #20
Old 08-07-2012, 08:59 PM
Lieutenant
Member's Gallery
Default
Randy, thanks for the suggestion, just who are these guys? Are they on PSA?
__________________
-Jon
  #21
Old 08-14-2012, 07:14 PM
Lieutenant
Member's Gallery
Default
So who is holing out on the secrets here? Relocating my alternator is inevitable, how am I going to overcome this problem?
__________________
-Jon
  #22
Old 08-14-2012, 10:32 PM
Major
Member's Gallery
Default
http://www.competitiondiesel.com/for...t=78783&page=2
In the middle of this thread it kinda talks about it. These guys are on here from time to time
__________________
RANDY
PRETTY MUCH STOCK
  #23
Old 08-14-2012, 11:46 PM
Extended Power's Avatar
Extended Power Extended Power is offline
Major
Member's Gallery
Default
I'm running the stock alternator, in the stock location. Soooo...I'm out.
  #24
Old 08-15-2012, 02:21 PM
Colonel
Member's Gallery
Default
It's pretty simple man, get a factory lower alternator, tensioner, belt pulley and mount. Than remove the upper.
The way the trusted one is, is exactly how mine was.
  #25
Old 08-16-2012, 07:05 PM
Lieutenant
Member's Gallery
Default
If the upper alt is removed then then there is too much slack in the main belt, as they mention in that competition diesel forum. Anyone have an idea where to get a shorter belt that they speak of?
__________________
-Jon
  #26
Old 08-16-2012, 11:23 PM
Major
Member's Gallery
Default
You know they sell different sized belts at all the autoparts stores right? Remove the alternator and reroute the belt.
__________________
RANDY
PRETTY MUCH STOCK
  #27
Old 08-17-2012, 11:41 AM
ncstroker's Avatar
ncstroker ncstroker is offline
Corporal
Member's Gallery
Default
I have the brackets, intercooler pipe and second alt fir sale i removed from my truck
Sent from my PC36100 using Tapatalk 2
__________________
2005 F250 Lariat- H-11, ******, Dozers Diesel Regulated Return, Airdog II, AFE, Optima, Looney Tune, Xtreme X, Autometer GS, Spearco, MBRP, NUC Bypass oil, 205cc/100% Warrens, Powermax w/ Batmo, Riffraff boots, Coolant Circulation lines, Alligator Sump, Detroit Truetrac, Mag Hytec, 08 mirrors, Recon everywhere, Royal Purple, Cat ELC, CFM Largemouth
  #28
Old 08-17-2012, 08:45 PM
Lieutenant
Member's Gallery
Default
ncstroker,
PM sent
__________________
-Jon
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
