HeavyAssault
Would a PCM from a 2wd truck work on a 4wd truck each with the same year motor and transmission? 2006 2wd 6.0 auto trans works on a 2006 4wd 6.0 auto trans?
I'm certain the donor truck is a King Ranch model. So it should have the 4ABS installed. Still no clear answer so I may just try to run it and see what happens.
