Heres a tough one that I can't figure out.
vanderchevy18
Benton, Ks.
The E99 F-350 will be running down the road and just stumble instantly and then come back. Almost like you shut the key off and then back on. Fuel psi is good, new cps, new icp sensor, good hpop psi, and everything else looks good. The tach doesn't drop when it does it and it only does it running down the road. It'll only do it a couple times in a 100 mile drive. Not constantly. Its got me stumped. TPS maybe? I just don't know. It does it whether the chip is in or not.
vanderchevy18
Benton, Ks.
Icp and smoke all look normal. I wouldn't be asking without checking first.
I checked the VC harnesses and the plug to the IDM and Pcm. They all seem tight and free of bare wires. I don't have any codes at all. I tried a switch test on the ol snap on brick and it wouldn't complete the test. I'm gonna try it on AE today. May try to watch TPS voltage next time I'm driving with someone somewhere in it. Never tried that though. Don't know if it can see that.
bad12jr
Double check the rear end. Especially pinion. My 96 did the exact same thing when the pinion bearing went.
Sent from my x2 somewhere
