Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 09-23-2012, 09:54 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
General
Member's Gallery
Default #18 fuse is blowing when I hit the brakes....no brake lights.
Ok, so got home tonight, and went to back up the driveway and noticed I had no brake lights. Running lights are working fine. Checked the manual...and sure enough the #18 fuse is blown. I replace it, and the soon as I hit the brakes, the brakes light up for a millisecond, and the fuse pops again.
Help.... I absolutely SUCK with electrical issues.....I already looked under the dash and couldn't find anything abnormal. Really need some help/troubleshooting assistance.
Thanks in advance, fellas.
From the Manual:
Quote:
#18 (20A*) Turn lamps/Brake on-off switch (high)
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
  #2
Old 09-23-2012, 10:22 PM
ToMang07's Avatar
General
Member's Gallery
Default
I should add the 3rd brake does not work, blinkers do not work, (front or rear) dash-turn indicators do not work, and 4-ways do not work.
FML.
__________________
  #3
Old 09-23-2012, 10:33 PM
TyCorr's Avatar
TyCorr TyCorr is offline
General
Member's Gallery
Default
#18? Isn't that the fuel bowl heater circuit? If so, there's your help.
__________________
IW local 393
  #4
Old 09-23-2012, 10:41 PM
ToMang07's Avatar
General
Member's Gallery
Default
Quote:
No, it's the brakes and turn signals. Per the manual:
__________________
  #5
Old 09-24-2012, 10:35 AM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Look for a wire shorting to ground. Probably back by the brake lights.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #6
Old 09-24-2012, 12:26 PM
mudwizer mudwizer is offline
Corporal
Member's Gallery
Default
see if you backed in your trailer plug
  #7
Old 09-24-2012, 01:04 PM
ToMang07's Avatar
General
Member's Gallery
Default
Quote:
Spent a LOT of time doing that. Found nothing but rust and grime.
Quote:
Nothing there, and I haven't since I owned the truck.
Update:
I think it is fixed. I got a tip on another forum to check the relay under the hood on the driver's fender and switch the 2. (Electronic Wiring Manual says one is for A/C, the other is for "Flasher Relay" which does not appear in the normal manual.)
Switched them...brake lights/blinkers work again, and no popped fuse! Woot!
__________________
  #8
Old 09-25-2012, 08:33 PM
TARM TARM is offline
Major
Member's Gallery
Default
Now you need to go and pick up the proper relay so your AC works when you need it.
__________________
01' Excursion (forged): ********'s tuning, GTX4294r-1.15t4, Nate's Stage 5 Firehoses 465cc/200%, Stealth's SP1, ARP Studs, 910's (shimmed), DI Pushrods (SAE 4130 CM), Full Custom Fuel System, aFe-Big Boost, DE 4" Exhaust, BTS Trans, 99'-04' V code front/08'F code rear spring swap, PMF 4"Hanger-Shackle kit/5"Rear Blocks, Custom Valved Blistien's, Rear Sway bar, Bushwhackers Cut-out Flares, Fuel Hostage 20"x12" Black Wheels, Interco M16 40"x14.50"x20" Tires
  #9
Old 09-25-2012, 08:58 PM
TrailerHauler's Avatar
TrailerHauler TrailerHauler is offline
Major
Member's Gallery
Default
That's strange. I would've guessed a short to ground around the back of the truck.
__________________
99.5 F350 PSD Dually
elovasz19@yahoo.com
  #10
Old 09-25-2012, 09:09 PM
Powerstrokeracing's Avatar
Powerstrokeracing Powerstrokeracing is offline
Lieutenant
Member's Gallery
Default
Next thing I would do is getting a wiring diagram and test for resistance in the wires..
  #11
Old 09-26-2012, 03:21 AM
PatriotHauling's Avatar
PatriotHauling PatriotHauling is offline
Sergeant
Member's Gallery
Default
Quote:
Lol he doesnt know how to do that.
He HATES electrical problems.
__________________
- Trey
2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, BW CPS, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
My Youtube videos
  #12
Old 09-26-2012, 06:31 AM
Arisley's Avatar
Mod Squad
Member's Gallery
Default
Wow. Relays fail in the strangest ways. I always have a couple of spare relays in my truck. At the age these things are getting, you never know when one is going to die.
__________________
SDRCM #478
  #13
Old 09-26-2012, 06:48 AM
ToMang07's Avatar
General
Member's Gallery
Default
^Yup.
__________________
  #14
Old 09-26-2012, 07:42 AM
JLDickmon's Avatar
JLDickmon JLDickmon is offline
Major
Member's Gallery
Default
I'd say maybe a shorted brake light switch.. I don't have diagrams for an 02, maybe I can find online..
try this link
Michigan Electronic Library
use login M123456789012
__________________
'99 7.3
  #15
Old 09-26-2012, 02:49 PM
ToMang07's Avatar
General
Member's Gallery
Default
Quote:
try this link
I figured it out...it was a relay. (See post #7) Thanks for the link, anyway.
Also, there is a link under the tech files with a PDF that has the electrons diagrams (ALL of them) for an 02 250/350/EX. VERY useful, only thing I wish it did better was show a diagram of WHERE on the truck the relays/fuses are.
__________________
  #16
Old 09-26-2012, 08:00 PM
JLDickmon's Avatar
Major
Member's Gallery
Default
It's called a "component locator" and there's one in the link I provided..
__________________
'99 7.3
  #17
Old 09-26-2012, 09:34 PM
ToMang07's Avatar
General
Member's Gallery
Default
I see/understand that. I was merely commenting on the on I used, which did not have a locator.
And again, thanks for the link!
__________________
  #18
Old 08-27-2015, 03:58 PM
viper59 viper59 is offline
Private
Member's Gallery
Default
Same problem trail work fine on 2 other ford trucks keeps blowing fuse #18 .
  #19
Old 09-01-2015, 11:11 AM
lightning95's Avatar
lightning95 lightning95 is offline
Private
Member's Gallery
Default
Quote:
Mine ended up being the brake pedal switch in cab under the dash. It takes all of 5 minutes to change.
__________________
02 F-250 CCSB 4x4 8" Fabtech lift, 37" Toyo M/T,hydra chip w/powerstruck tunes,Riff Raff Wheel,4"exhaust, AFE intake, Trans Go Tugger Kit
95 Lightning 4" Bell Tech drop, 20" wheels,NX 150 shot, Trans Go shift kit
07 Yamha R1
05 Harley Sportster 1200 cammed up
  #20
Old 06-22-2020, 03:46 PM
cranstol cranstol is offline
Private
Member's Gallery
Talking My fuse#18 issue
Thank you all above for the input and things you found. I thought it would be appropriate to share my experience tracking this down on my 2003 Excursion.
Every single time I touched the brakes... *POW*, #18 blew. Started looking for obvious stuff, but nothing.
Disconnected trailer plug etc. via the connector behind the license plate. Tested *POW*
Moved up to the mid-frame area on the drivers side. Disconnected the back end lights from there. *POW* Good thing I have a 20 pack of 20 AMP fuses.
Disconnected those same cables from under the hood right in front of the firewall. *POW*
Disconnected the brake switch. Did not blow, but no brake lights of course. Manually jumped pin 4 and 5 of the brake switch connector. Found a schematic online and those are the contacts bridged by the switch on the 20 amp circuit. *POW* on the manual jumper. Something elsewhere...
Pulled all the relays, etc from the two block areas under the hood just in front of the driver. *POW* The issue is getting in a smaller and smaller area.
Pulled the entire fuse block / power distribution block lose under the dash. 4 bolts 10mm heads. Got a good look behind. Saw nothing. Ready to give up. Tried one last fuse (still have 10 or so left)... maybe it was MY last fuse. :-) Tried the brake, no blow! What?!?
Added relays, etc. back. Tested. *No blow*
Added connectors under hood. *No blow*
Added mid frame connectors. *No blow*
Added connector behind license plate *No blow*
Mounted fuse block / PDB *No blow*
Everything is back together and working. Driven 150+ miles since and it is still working. Not the outcome I exactly wanted as I wonder when (not if) it will pop up again. Hopefully the extra details of the things I did will help someone else down the line with diagnostics.
2003 Excursion 6.0L Limited
2000 Excursion 7.3L Limited
1971 Suburban dead 350 :-(
  #21
Old 06-23-2020, 07:39 AM
Arisley's Avatar
Mod Squad
Member's Gallery
Default
Probably one of the bolts holding in tthe fuse box was touching a wire in the brake circuit. Over time it wore through just a tiny bit. Hard to see. When you pulled the block you moved the wire and when reinstalled, it was no longer toughing the bolt.
__________________
SDRCM #478
  #22
Old 06-23-2020, 07:41 AM
fastersteve fastersteve is offline
Sergeant
Member's Gallery
Default
Aaack! I hate mysteriously self repairing issues!
__________________
2001 Excursion LTD
AIS, 4" MBRP, SRP 1.1, ******** Tunes, HD4R100, 38R with a Turbomaster. Bigger injectors on the way
Family race car hauler
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
